Washing Green Stuff before priming?
NiceGuyAdi
I've been making some forays with Green Stuff this evening (and I'll be doing some Milliputting tomorrow, too). I've been fairly liberal with the Vaseline as I've worked. Before I prime the miniature, will I need to get that off, and if so, what's best to do that with?
Vaseline is oil-based (that's why it's discouraged from use with latex-based protection for private life , it swells and damaged it) so you can remove it with multiple soapy warm water washes or any detergent. Make it foam a bit before use so that you don't end up with soap or detergent left behind after rinsing . Make sure it dries overnight as small recesses will hold water for some time
I use water to sculpt greenstuff so I just let it dry a day or two and prime chaos black directly on it
Wash with dishsoap and warm water - twice - and then prime and paint as normal.
You just have to make sure you get all the vaseline off, and that's basically it. Greenstuff otherwise primes/paints just like plastic models do.
Never had experience with this, but feels like the FW resin process would work well.
Wash in hot soapy water
Spray with Purity Seal
Undercoat
No, no, no, no, no. The Purity Seal before undercoat thing is a persistent, false myth that is utterly rubbish. Purity seal is not an undercoat and does not function as one, nor does it strengthen the bond between miniature and paint. On the contrary: it will weaken the bond between your miniature and the paint you're going to use.
Just give your FW and Greenstuff a good rinse with warm water and soap. Wait to dry and then just use an undercoat, preferably a canned undercoat - as that has additional thinning agents that will dissolve and thus partially neutralize any remaining grease particles.
