Iconic Canoness is coming this weekend.
Personally I have a lot of luck with Gorilla brand superfluous. It seems to be slightly less brittle than other glues.
Before assembling/painting resin often needs a soapy water bath and light scrub with a soft toothbrush (just like you do with metal) as mold release agent can still be on the model causing glue to fail to adhere properly or do weird thing to your paint.
It was small bottles of medium zap, one was opened last week & was fine then, the others were still sealed until I tried to use them. Nothing I applied it to bonded, nothing! Resin, plastic, paper, skin! Nothing!
I suspect my use of kicker during the previous building session must've disguised that the it wasn't working as normal.
That allows it to be taken by Adepta Sororitas but it does not change its faction.
I would agree with that if it specified what faction they are. Also, it's pretty much the same wording as in the IA that lets us and guard take the  Avenger as a Heavy Support Choice
The closest other example of this I can see on the datasheet is in 30k where it "may be used either as part of a Mechanicum Taghmata army as a Lords of War choice as normal, or as part of a Questoris Knight Crusade Army." When it (or anything similar like the Cybernetica taken with that Consul) does this it counts as the faction that it was taken with. This is significant in 30k because Battle Brothers isn't a thing and even the closest allies have restrictions on what they can benefit from each other.
