Sevej Posted December 15, 2016 Share Posted December 15, 2016 Is there anyone who's ever made/buy "generator" for razorback? I'm talking about something like a resin piece that can sit on top of a Rhino chassis interior, covering half of the space (and seat). Link to comment https://bolterandchainsword.com/topic/328789-generator-for-razorback/ Share on other sites More sharing options...
Bjorn Firewalker Posted December 15, 2016 Share Posted December 15, 2016 What's the generator for? An ion shield or void shield? An auspex or other sensor array? An Executioner plasma cannon or other heavy weapon? Link to comment https://bolterandchainsword.com/topic/328789-generator-for-razorback/#findComment-4593567 Share on other sites More sharing options...
GreyCrow Posted December 15, 2016 Share Posted December 15, 2016 What's the generator for? An ion shield or void shield? An auspex or other sensor array? An Executioner plasma cannon or other heavy weapon? It's probably for a Lascannon. The Razorback cuts the Rhino transport capacity for ammo/firing system storage ;) Link to comment https://bolterandchainsword.com/topic/328789-generator-for-razorback/#findComment-4593569 Share on other sites More sharing options...
Bjorn Firewalker Posted December 15, 2016 Share Posted December 15, 2016 What's the generator for? An ion shield or void shield? An auspex or other sensor array? An Executioner plasma cannon or other heavy weapon? It's probably for a Lascannon. The Razorback cuts the Rhino transport capacity for ammo/firing system storage Makes sense. Link to comment https://bolterandchainsword.com/topic/328789-generator-for-razorback/#findComment-4593583 Share on other sites More sharing options...
Sevej Posted December 15, 2016 Author Share Posted December 15, 2016 Yeah, would be cool right to have a generator cramping the cabin (and optional parts for heavy bolter ammo or lascannon power cells)? Link to comment https://bolterandchainsword.com/topic/328789-generator-for-razorback/#findComment-4593591 Share on other sites More sharing options...
Halandaar Posted December 15, 2016 Share Posted December 15, 2016 Well, I guess the problem is that the rear ramp and side doors are all still usable, so how would you effectively reduce the internal capacity without impeding access to all 4 doors (including the one into the drivers cabin)? Link to comment https://bolterandchainsword.com/topic/328789-generator-for-razorback/#findComment-4593839 Share on other sites More sharing options...
Jolemai Posted December 15, 2016 Share Posted December 15, 2016 No link because it's an eBay shop, but can I suggest the tank dynamo and/or large fuel tank that's available on Blood and Skulls Industries? Link to comment https://bolterandchainsword.com/topic/328789-generator-for-razorback/#findComment-4593856 Share on other sites More sharing options...
Sevej Posted December 21, 2016 Author Share Posted December 21, 2016 Thanks Jolemai, I'll check it out! Well, I guess the problem is that the rear ramp and side doors are all still usable, so how would you effectively reduce the internal capacity without impeding access to all 4 doors (including the one into the drivers cabin)? Ideally, it would be a resin piece that sits on top of the seats: Still full access on all doors and instruments. The right half of the ramp is for reenergizing/reloading the ammo. Link to comment https://bolterandchainsword.com/topic/328789-generator-for-razorback/#findComment-4599043 Share on other sites More sharing options...
Master Antaeus Posted December 21, 2016 Share Posted December 21, 2016 Interesting. I would think that the door would have to be completely clear. If you build the turret ring in the center instead of at the back with the rise, it is likely that the power feeds pass into the hull with either a self-contained, rotating auto-loader/capacitor (depending on the armament) that would need to be kept clear. This means that the viewport/bolter bracket would be inaccessible and the turret would probably have to be turned a certain direction in order for the driver/gunner to squeeze past the auto-loader. This also means that the side doors would be blocked and the additional weight anchored to the top of the vehicle would mean a much higher chance of rollover. Interestingly, the Sisters of Battle Immolator solves most of these by putting the turret, ammo stores and the gunner on top. This would free up most of the space in the fighting compartment while contributing to the rollover concerns. Also of note: the addition of a turret ring mitigates the weakness of cutting a hole in the top of the hull. Link to comment https://bolterandchainsword.com/topic/328789-generator-for-razorback/#findComment-4600004 Share on other sites More sharing options...
Deanoprime Posted December 26, 2016 Share Posted December 26, 2016 On the heavy bolter razorback that I built, I kitbashed a representative turret basket and a feed as if the HB rounds were being transferred from the underfloor ammo store. IRL, i believe, the M113 and the Bradley both utilised underfloor ammo storage so I thought why not the razorback. As regard the lascannon version I would think that representing the energy bank required to power the cannons would be good. It's a pity the vehicles aren't to proper scale but hey you gotta do what you can with what you have Link to comment https://bolterandchainsword.com/topic/328789-generator-for-razorback/#findComment-4603832 Share on other sites More sharing options...
Deanoprime Posted December 26, 2016 Share Posted December 26, 2016 ##duplicate post as i thought previous post hadn't saved## Link to comment https://bolterandchainsword.com/topic/328789-generator-for-razorback/#findComment-4603833 Share on other sites More sharing options...
cephalopod Posted December 27, 2016 Share Posted December 27, 2016 Cool. Like the idea. But it's future tech. Would it not be smaller? Consider the size of a dev marines pack. Powers his armor and the laz cannon. Easy fix.. Stick a devs backpack in the opening by the door. Then run an amo belt (green stuff) and or wires depending on your préférences of weapon. Link to comment https://bolterandchainsword.com/topic/328789-generator-for-razorback/#findComment-4603980 Share on other sites More sharing options...
Master Antaeus Posted December 28, 2016 Share Posted December 28, 2016 2 dev packs, because it's twin-linked. I love it. Link to comment https://bolterandchainsword.com/topic/328789-generator-for-razorback/#findComment-4605565 Share on other sites More sharing options...
