Maarten Posted December 17, 2016 Share Posted December 17, 2016 After watching a whole bunch of tutorials on how to magnetize the Baal predator I was thoroughly dissapointed in how they all chopped the fins or the ejection ports off. So here's my solution, requiring only 2 square magnets for an infinite amount of weapon options. The little gap in the elevation parts of the turrets is wide enough to stick a 2.5mm thick magnet in sideways. Now due to how magnets work they also stick to each other's sides. The ones I used were about 6x4x2.5 and were fit with the long sides together. The only cutting required(okay I lied a little bit) is on the squares at the back of the weapons, but since those are totally invisible for the outside (and way too long to begin with) a little cutting isn't too bad. Anyway, picture time! http://i.imgur.com/qYoqZUW.jpgThe parts all laid out, you can see the magnets in the turret and the cover parts. Glue in one first, stick the other to it, then glue the cover to the second magnet. Picture showing how flawless the setup looks when attached together: http://i.imgur.com/6Lwi2D6.jpg Link to comment https://bolterandchainsword.com/topic/328854-maartens-no-cutting-baal-pred-magnetization/ Share on other sites More sharing options...
Stercus Posted December 17, 2016 Share Posted December 17, 2016 Nicely done. Would it work for a standard predator turret too or is the method specific to the Baal variant? Link to comment https://bolterandchainsword.com/topic/328854-maartens-no-cutting-baal-pred-magnetization/#findComment-4595849 Share on other sites More sharing options...
Maarten Posted December 18, 2016 Author Share Posted December 18, 2016 On 12/17/2016 at 6:01 PM, Stercus said: Nicely done. Would it work for a standard predator turret too or is the method specific to the Baal variant? Nope, normal predators have the hinge pin as a part of the weapon option. Link to comment https://bolterandchainsword.com/topic/328854-maartens-no-cutting-baal-pred-magnetization/#findComment-4596050 Share on other sites More sharing options...
Stercus Posted December 18, 2016 Share Posted December 18, 2016 That's kind of annoying. Link to comment https://bolterandchainsword.com/topic/328854-maartens-no-cutting-baal-pred-magnetization/#findComment-4596357 Share on other sites More sharing options...
Arkaniss Posted December 19, 2016 Share Posted December 19, 2016 Very similar to how I did mine, though your solution is more simple and efficient. Nice work! :) Yes it's a shame about the standard Pred kit... I think it's long overdue a revamp, making it like the Baal Pred would be awesome. Along with a better and more easily magnetised turret setup it's far superior and more durable sponson design would be most welcome. Link to comment https://bolterandchainsword.com/topic/328854-maartens-no-cutting-baal-pred-magnetization/#findComment-4597038 Share on other sites More sharing options...
Maarten Posted December 19, 2016 Author Share Posted December 19, 2016 I'm gonna build some weapon options to represent the other options in the Legiones Astartes book. First up would be a special autocannon setup and a magnamelta. If they're easy enough to build I'll make a tut. Link to comment https://bolterandchainsword.com/topic/328854-maartens-no-cutting-baal-pred-magnetization/#findComment-4597522 Share on other sites More sharing options...
