Magos Takatus Posted December 17, 2016 Share Posted December 17, 2016 Hi. I'm just finishing a squad of models and I have just applied some waterslide decals. Now is a sensible time to apply some varnish to the area. I noticed when prepping for the decals that my pot of 'Ardcoat has thickened slightly and I used a bit of water to thin it but still looked uneven when wet. What would you suggest for thinning down gloss varnish like 'Ardcoat? I'm concerned that the varnish won't mix that well with water and that I should try Lahmian medium instead? I need to smooth the consistency while reducing the glossy properties as little as possible. I am guessing I should just add more water than I did since washing my brushes with water is sufficient to get the varnish out of the bristles? Link to comment https://bolterandchainsword.com/topic/328866-ardcoat-is-too-ard/ Share on other sites More sharing options...
Race Bannon Posted December 17, 2016 Share Posted December 17, 2016 I'm not an expert, yet I used Lahmian Medium to thin 'Ardcoat. Since I wanted a very thin coat it was almost 1:1 in a separate pot. Admittedly, I also went the lazy man's path and bought Vallejo Brand gloss varnish because it was naturally thinner than 'Ardcoat. Link to comment https://bolterandchainsword.com/topic/328866-ardcoat-is-too-ard/#findComment-4595753 Share on other sites More sharing options...
Atia Posted December 17, 2016 Share Posted December 17, 2016 GW varnish is water soluble afaik :) Link to comment https://bolterandchainsword.com/topic/328866-ardcoat-is-too-ard/#findComment-4595796 Share on other sites More sharing options...
Magos Takatus Posted December 17, 2016 Author Share Posted December 17, 2016 Thank you both for your help. I've not dabbled in Vallejo products but I might look into it down the line. Thank you both for the advice. Link to comment https://bolterandchainsword.com/topic/328866-ardcoat-is-too-ard/#findComment-4595854 Share on other sites More sharing options...
