Interchangeability of Leman Russ turrets
The turret gun mount is different on the two Russ kits, so you can very easily magnetise/swap the Demolisher variant weapons but they won't port to a Battle Tank turret. The Battle Tank kit doesn't lend itself to such easy conversion unfortunately but it is possible. Check out our magnetisation tutorials for more detail :tu:
Thanks for the info.
I magnetized at the swivel point/tabs in the regular Russ. It kinda looks like the Punisher kit has a swivel part similar to the Chimera's weapon mount. If that's the case, I can slice if the tabs on the weapon mount and add magnets there.
