General Strike Posted December 21, 2016 Share Posted December 21, 2016 So, I want to use Stormcasts to make Astartes, I might use the Cataphractii shoulder upgrades for my chosen Chapter. I might use the Mk2 or Mk3 FW pauldrons instead. I want to use the Judicators with the boltstorm and convert those into bolters and combi-weapons. Then I want to pick up some more of the Thunderbolt crossbows(the big ones) and use bits to make them Multi-Melta, Missile Launchers and Lascannons. Most of the weapons can be matched up, even using the swords as chainswords if I need them. I can also use the chainswords without hands from BoP. My question is, what chapter do you think fits the aesthitic best? And, what models or how could I modify models to run Terminators if I'm going to use stormcast as Tacticals and Assault marines. Should I just run stormcast with the appropriate weapons(TH/SS, lightning claws, stormbolters, assault cannons,etc) to represent the Terminators? Link to comment https://bolterandchainsword.com/topic/328984-another-stormcast-eternal-conversion-question/ Share on other sites More sharing options...
Grotsmasha Posted December 21, 2016 Share Posted December 21, 2016 For Terminators, the Retributer models are larger and than the standard Stormcast models. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/328984-another-stormcast-eternal-conversion-question/#findComment-4599164 Share on other sites More sharing options...
General Strike Posted December 21, 2016 Author Share Posted December 21, 2016 Thank you, that's perfect. :) Link to comment https://bolterandchainsword.com/topic/328984-another-stormcast-eternal-conversion-question/#findComment-4599166 Share on other sites More sharing options...
