Marines becoming true-scale?
Jackalwolf
Hey there fellas,
I've been noticing lately that GW and FW have been progressively increasing the size of their marines, up to the point that they're starting to become well proportioned.
The FW Character Series and event only miniatures seem to have gone true scale for a while already.
On normal marines, particularly the MKIII from Prospero, I find that if you add a bit of greenstuff between the legs and torso to give them more abs (since that's the one aspect I feel they lack the most for proportion) and a smaller head, they're pretty much bang on proportioned other than maybe the hands being a bit too big.
What are your thoughts guys?
EDIT: Just to clarify, I'm not referring to their comparative size to other miniatures but their body proportions (sort of what do they look like if you overlay them on the Vitruvian man).
https://bolterandchainsword.com/topic/328993-marines-becoming-true-scale/
Yes and no. I think the more upright poses GW have been doing lately appear to be better proportioned compared to the traditional "crouched" poses but I think that's just about stance and it's an illusion rather than actual proportion changes.
That being said, you are correct about the FW character series, they are bigger. And the new 40K Ahriman looks extremely tall too. Space Marines vary in size just like normal people though so I don't think it will ever become a problem. It is kinda nice for your heroes to tower over their comrades.
I really don't see GW ever doing proper "true" scale as their models won't look right. The Lord of the Rings miniatures for example are propotionally accurate, except for the heads and hands which have to be enlarged or they just don't look correct at that scale. The same would apply to models in 40K.
In the grim darkness of the far future, there will always be bananna-handed, bobble-head men.
If I may, here's a reference comparison between a BoP space marine and the Vitrubian man:
http://i1379.photobucket.com/albums/ah128/Grieux/Vitrubian%20Marine_zps2mzyzmvr.jpg[/url
Seems pretty bang on excepting the tibia and perone being comparatively shorter, but I can get by since different gravities promote different lengths of leg in theory so :p
The scale is definitely improving... slowly. The deathwatch miniatures look pretty great for example. A problem previously was that marines didn't look a lot bigger than 'normal humans'- as much an issue with the Imperial Guard models as anything else. If you put marines next to historical miniatures, say, that makes them look a lot more hulking!
I use Veteran sergeant/Heinrich technique to extend the legs using plasticard. It's a chore so I'll probably convert a few masters and make mold for them. The addition of 3-4mm in height on regular marines and 2-3mm on Terminators fixes all the scaling issues.
This is probably my favorite look, but as you say, extending the legs was such a chore that I shifted to the 'art scale' terminator conversion that's become a lot easier with the tartaros and cataphractii legs. I've grown on the added bulk and the way it seems to mimic the art of the HH books. Not for everyone, but works for me.
After thinking about it for a while, I don't think Marines are meant to comform to regular human proportions. They're always described as overly broad (particularly in the face) with enlarged shoulders giving them no neck. They are meant to be a little off.
Have you seen some Rugby or NFL players? ;p
Lol. Yes I have, some true Thunder Warriors there. Rugby players in particular are probably very good to base face sculpts on.
What is this method? It sounds interesting if it matches the Neil Roberts covers!
I always thought their torsos were too short
Yup. People mistakenly believe it's the legs that need lengthening when it's the torso that's the problem. For my BCK Scaling™ I lengthen the torso and thicken the upper legs.
http://i.imgur.com/v8JToIv.jpg
A few mm of extra length in the torso and larger legs make a difference, eh?
Here's a better look at how I trim down the marine torso and use plastic tubing cut to fit the shape of the torso as an extender.
http://i.imgur.com/3LbGQ40.jpg
Artscaling always has elements of 'David's Hands and Genitals'. Your perspective determines the accuracy of the sculpture. BCK's method is closer to the true anatomy of abnormally proportioned human (the head should fit in the ribs, is the rule IIRC). If you lack the requisite GS skills though, extending just the legs at the thighs and and shins brings it closer in line with the Kopinski artwork that defined space marines for years, with lankier leg proportions and smaller heads. For a heroic scale game, height is your immediate pass for scale.
I'll post this image over here as it will give some showing of scale in size, if not proportion, between the new Legio Custodes and other 'standard' human models.
Read: The Custodes are freaking monstrous.  I wish I had some 30k marines to put into the size comparison but the only ones I have on hand are old metal ones which aren't exactly relevant now.
http://i.imgur.com/UJNtBr3.png
I use two pieces of 1.5mm evergreen plain sheets, stack on top of one another. Using full 3mm thickness burns through knife s so fast. Cut the cataphractii shin at the middle 'band' of armor in the back and add your sheets to the waist (you might need some GS gap filling. Brother Heinrich's blood angels log had some great images you can use as a reference. I'd link them but my phone isn't cooperating :(
Huh, perspective, or are the SA large than the other FW humans?
I'll do a more comprehensive scale picture when I get home, I think it's the bulk of the SA armor. I always chuckle at how thin Elysians and that Commissar are, so I'll give some more pose accurate pics.
EDIT:
Alright, this is as comprehensive as I was able to get it, I wish I had some new marines to put into the line up but unfortunately I do not as I don't ever play Space Marines!
http://i.imgur.com/nm8SwxB.png
