major higgins Posted December 26, 2016 Share Posted December 26, 2016 I'm building a list of SA, and I spare enough points to fit in 2 Leman Russ Incinerator, or 2 Medusas (and few equipment here and there). My major doubt is? Are two Russes goos as two Medusas in terms of game play and performnce? My list has 3 Rapier lasdetroyers, 2 Vanquishers (one is a command tank) 1 Drakosan and 2 Flanking regular Russes in order to cope against enemy tank. Pros as I see for LRI High Armor Value 4 HP Good against LV and Infantry Long Range 45" Cont as i see for LRI Worthless against Land Raiders (my friends run from one to four of them) just 10 shots which have no real AP against anything Cannot Outflank Pros as I see for Med 5" str 10 AP2 Pie Plates Good against vehicles as any kind of infantry Good front armor Cont as I see for Med Short range Could scatter and hit nothing Big fire Magnet This is what I think, and I can decide because both choices have Pro and Cont. Could you give me your advise on them and their game use? Thank you Link to comment https://bolterandchainsword.com/topic/329169-russ-incinerator-will-worth-its-point-cost/ Share on other sites More sharing options...
depthcharge12 Posted December 26, 2016 Share Posted December 26, 2016 I think you should run Incinerators...mostly due to rule of cool. Pie plates from Medusas are cool but too many and you'll wind up without friends lol. Other benefits the Incinerators have going for them is mobility and the better usage against medium armor. Not everything is a land Raider in the heresy, and stripping hull points while getting nice side armor will be invaluable. They will be a lower target threat, so will be able to dominate the field in terms of mobility and surviveability by being a lower priority target. Link to comment https://bolterandchainsword.com/topic/329169-russ-incinerator-will-worth-its-point-cost/#findComment-4603646 Share on other sites More sharing options...
God-Potato of Mankind Posted December 26, 2016 Share Posted December 26, 2016 Bear in mind Tank Commanders - giving them tank hunters makes them adept at stripping HPs on light to med armour. PE (Ifantry) makes it even better at what volkites exist to do. The other rules are nice - I think the anti-MC one would do well against Mechanicum. I forgot the other rules... Oh and with a Strategos you can get them BS5 and with a Lord Marshall you can choose shred for the Russes with blast weapons which is lulzy with PE. I never leave home without my tank aces. Link to comment https://bolterandchainsword.com/topic/329169-russ-incinerator-will-worth-its-point-cost/#findComment-4603706 Share on other sites More sharing options...
Memento Of Prospero Posted December 26, 2016 Share Posted December 26, 2016 The one line than comes to might when I think about the LRI: "MAKE CHOOM GREAT AGAIN!" Link to comment https://bolterandchainsword.com/topic/329169-russ-incinerator-will-worth-its-point-cost/#findComment-4603760 Share on other sites More sharing options...
