Predictions for 2017 Astra Militarum
So is it then worth to start AM? If GW is planing to put us way back in the field with little new support (or a total new range where much change), should I (and several other new players) really invest in a AM army based on Cadians and corrent miniatures?
That sounds like guard since 3rd ed. So I wouldn't let that bother you. Similarly I've been waiting for plastic models other than catachans and cadians since then too...
I could understand some hesitation with the new edition around the corner. However I can't see the guard lines or codex changing drastically with the new edition.
Guard have never been a top tier army, unfortunately I don't have much reason to ever expect that to change. I don't see a model revamp any time soon either as duz says, so if you want to start Guard that will likely not be a factor :)
I've never seen anyone start Guard because they only want the strongest codex; we play Guard because we like them. I'd argue that's the best way to collect any army msn-wink.gif That Guard players have a tendency for various grades of lunacy is perhaps another matter laugh.png
The only thing I expect is them to replace the 29 dollar box of ten with a 40 dollar box of ten (and similar changes to all other kits, like a new chimera that costs as much as the new genestealer tank) they may well make them more garish in appearance, and the box will come with more bits you can't use due to lack of bodies.
Other then that, idk.
I heard all armies will get new codexes all at once but guard won't get new models (unless they make new units) as the current cadians "are fine".
If that is true, it'll be because the rules changed enough to invalidate every codex... they sorta did that with 3rd edition when every codex was rolled into the brb.
I sure hope they aren't some rediculous $50 a piece codexes because I won't be able to play hardly any of my armies for a long time...
Guard are a profitable line for GW. They wouldn't just squat them. I'd say there are also the most expensive $$$ wise army to collect and play effectively. IMO we don't need that much to bring up  a tier competitively ie Drop point cost across the board, For the love of the emperor do something with Roughriders(weather it be "Bikes" or better rules" Revamp Ogryn rules maybe access to grav...(which could break the game potentially) but our model line isn't bad. It would be nice for more "plastic" choices but in all honesty we have like 7 various ranges to choose from for basic infantry, no other army can claim that. Also they really could use a special squadron rule so it's not so detrimental...Guard just need a "soft" update and it will be fine.
Krash
Oh.. what guard needs. I thought the topic was what we expect... lol
Needs?
Return of lumbering or similar to the Leman Russ tanks.
Regiment tactics (cadian, mordian, steel legion, catachan, etc)
Drop rediculous point costs of character weapon upgrades.
That would be "enough"
Hopes for Rules changes:
Orders go off auto within 12" or with vox (otherwise too far away to issue)
PCS, CCS can blob with ANY platoon squads
Can order from/to inside chimera/taurox
Dedicated transports count as part of unit (fire/move/ECT with orders)
World's without number: can elect to swap transport versions with any version in current IOM codex (must pay the price from that codex)
Weight of fire: any model/ unit hit with lasguns suffers the following penalties for the rest of the turn (once wounds are scored):
Hit by 15 shots - minus 1 AC (including invulnerable)
Hit by 20 shots - minus 1 T
Hit by 30 shots - no cover saves of any kind
Russes gain back lumbering and split fire on main gun (sponsons shoot before ordinance, or snap fire). Squad Russes must target same unit with main guns (unless split fire order)
HW teams get t5
Armory:
2 points: flamer, sniper, bolter, lascarbine
5 points: melta, plasma, HBolter, GLauncher, sbolter, HS lasgun, mortar
10 points: autocannon, Mlauncher (w/skyfire rounds), power weapon, plasma pistol, hflamer, HS volley
15 points: lascannon, power fist, melta bomb
Following count as heavy: HBolter, mortar, autocannon, mlauncher, lascannon, HS volley
Lascarbine: S3 AP5, assault 2 18"
HS Lasgun: S4 AP3, rapid fire, 24"
HS volley: S5 AP3, Salvo 2/4, 24"
Mortar is now heavy 2
Vehicle upgrades stay the same plus:
10 points: veteran crew (+ 1 bs)
15 points Bird hunters (can elect to skyfire all weapons for a turn), tank hunter (2 dice for pen or damage) or monster hunter (wounds do D3 on MC)
HQ
60 CCS base - medic, vox, & 4 vets
commander always has carapace
lasguns, pistols, and CCW all around
5 points for banner (stubborn within 12")
Upgrades: 10 pts for carapace, 10 for cammo cloaks, all can take from list
All officers are 15 points
Commissars, priest get a 5 point reduction
Primaris is now 40 points
30 points for techpriest AND one servitor (upgrades stay the same for servitors)
20 Tank commander stays same, can order up to 2 tank units to gain split fire, twin linked, bird/tank/monster hunter
OR
coordinate fire (give BS to all tanks within 12" for the turn)
30 tank commissar , 3 orders, 5 BS, same as above
Psykers are 10 points, can't take gear
Troops:
30 PCS, commander 4 guardsmen, vox
Can take Chimera, taurox, valkerie
50 infantry squad, lasguns
HS Lasgun, Heavy bolter, vox, frag grenades
Sergeant can take any non heavy from armory
Upgrades: HS Lasgun and/or HBolter to any other 5 point from list free, any from 10 point for 5
5 points for Krak grenades
Can take Chimera, valkerie
55 infantry combat squad, lascarbines, laspistols, CCW
2 Flamer, heavy flamer
Flamers can swap for non heavies from list
Can take Taurox, valkerie
50 Heavy weapon squad, 3 heavy bolters/mortars
Upgrade to AC, ML for 5 points, LC for 10
40 special weapon squad Sergeant and 5 guardsmen with HS lasguns
Sergeant and 2 others can take any non heavy in armory as an upgrade
Can take valkerie
Conscripts stay the same
60 Veterans take either lasguns or lascarbines.
CCW, laspistols, frag and Krak grenades
Either 3 hotshot lasguns, 3 heavy flamers
All 3 can swap for any weapon in the armory (heavy weapons are held alone)
Sergeant can swap for any non heavy
Grenadiers and sentries stay the same, demo is 20 points
Can take chimera, Taurox or valkerie
Transports:
55 chimera multilaser and HBolter
12/11/10
Can swap either for HBolter, hflamer
Can take Autocannon, TL HBolter for 5 points
40 Taurox same as before
100 Valkerie transport
Lascannon for 5, rocket pods for 5, bolters for 10
Eletes:
100 Ogryns: add fnp 5+, 30 per model
Ripper gun: S5 AP5 18" assault 3 (can be used in assault)
Can take chimera
115 Bullgryns: add fnp 5+, 35 per model,can ADD mail and shield for 15
Can add Chimera
50 Wyrdvanes: 10 per extra, power level 2 if 10 models
Ratlings: change to move-fire-move, can squad up or start game attached to units (1 per)
Tempests platoon removed (have their own army)
30 Scout sentinel, multilaser
Same upgrades,
5 points swap for HS Volleygun
10 points, add power claw
35 armored sentinel (see above)
50 Armored Scout Cavalry
(Rough riders on cav/bikes/ECT)
Add T4, jink, Lasgun carbines, 10 points per model
2 riders can replace carbine with non heavy from armory
Hellhound chassis get 25 point reductions and 11 rear armor
150 Vendetta, same with sponsors only costing 10
Leman Russ all get free pintle stubber, sponsons 10 points cheaper, no more gets hot on plasma, add HS volley sponson for 15 points
Pintle mounts grant TL if they hit first
Exterminators get rending,
Vanquishers become SD on a 5 or 6 to hit
60 Hydra
100 basilisk
60 wyvern
150 manticore
150 Deathstike (now SD blast)
Thoughts?
Whilst not Guard I guess they come under the same banner, Id love to see a few simple updates for the Scion codex, even if it was a forge world release I would be happy.
-A named character or two (scions have non)
-Relics (scions have non)
-Access to either the Vendetta or Vulture in a heavy support slot. Maybe price them high with extra BS like D-99.
-Allow Tempestors and Primes to take Melta bombs, not just lord commissars
I love the extensiveness of your thoughts!
In general I have to agree that overall (our beloved Wyvern aside) IG units are about 20% more expensive then they should be in the current meta.
Even 4pt Guardsmen makes an enormous difference when you're trying to field them in massed quantities: 100pts for a platoon rather than 130 is massive.
The other "categorical" issue with Guard is that they are supposed to be a big, lumbering heavy force compared to more nimble forces like SM (generally speaking), Eldar, et al. The problem is that we are heavy without really being resilient or particularly dangerous at shooting.
Worst offenders in that regard would be the Chimera and the Basilisk.
AV12 Chimera with a 3-shot S6 gun is exactly the sort of statline that someone with a spreadsheet would think is good....until you realize it's BS3, AV10 on the sides, and almost double the cost of a Rhino.
The Baslisk likewise sounds scary (S9 AP3 Large Blast!!!!!!!!!!)....until you realize it's BS3 (scatter), cover saves abound, and it's a single per Turn (so 5 shots in a game if you're lucky) for 125pts. Either cut it's points to 100 or less, or update it's rules so that it's reduces enemy cover saves somehow, 6's To Wound Ignore Cover, 5's are -2, 4's are -1, enemies hit by it suffer Strikedown/Crew Stunned, or must pass Dangerous Terrain/Morale checks next Turn. I mean, it's called the EARTHSHAKER cannon, after all.
I also really like the idea of T5 Heavy Weapons Teams. They are gun-emplacements (modeled with sandbags, after all) and so should have artillery-lite rules. And can take camo netting that's +1 to Cover if they have not moved. T5 2W 5+ with a 4+ cover save represents the gun pits they should be. The kind of entrenched heavy weapons that an entire platoon would revolve around.
Lastly, to hear myself mention it yet again, I think Commissars (and many other specialists) should enhance units rather than make them less worse. What does a Commissar currently do? Help them not fail Morale checks. They should be buffers that give +1A and re-roll 1's To Wound or something. The men around them are more terrified of hte Commissar then they are of the enemy....and the battlefield results show!
Quick thought: multilasers as infantry heavy weapons and heavy stubbers as specials.
I like the idea of Multi-lasers being the "standard" IG heavy weapon instead of bolters.....and they could benefit from FRFSRF as well?
Given priests have rendered Commissars completely useless from a rules standpoint, how about emphasize the training and leadership skills of a Commissar?
Say, give Commissars the ability to issues junior officer orders to the squad they're attached to as well as some sort of defensive buff - like counter attack of BS2 overwatch to emphasize their "Hold the line!" mentality.
As frankly, when for the same points you have a unit which gives fearless, hatred and the possibility of re-rolling all defensive rolls, they just serve no purpose - which is a common theme in the Guard codex - lots of completely useless or redundant units.
