suxdavide Posted January 7, 2017 Share Posted January 7, 2017 Hello I bought the minis for an AL 30k force, I now want to change a bit from the DA I've been painting for the latest months buuuuut I'm not ver yskilled and looking for help. Some questions:1) I'd love to make them the darker scheme, a friend suggested the tamiya's blue metallic so I bought it. Has anybody painted with it and has suggestions?2) Black or White primer? Is GW's good enough?3) Which colors for the other details? (Bolter / junctions / Pads etc)I obviously have no airbrush thanks in advance :) Link to comment https://bolterandchainsword.com/topic/329605-alpha-legion-which-colors-and-step/ Share on other sites More sharing options...
Xenith Posted January 8, 2017 Share Posted January 8, 2017 Get GW leadbelcher or runefang steel. Add the blue citadel tint (Kurze?) to taste. You now have your own metallic blue paint. GW has a video of Duncan doing exactly this. Link to comment https://bolterandchainsword.com/topic/329605-alpha-legion-which-colors-and-step/#findComment-4616308 Share on other sites More sharing options...
IronDrake28 Posted January 8, 2017 Share Posted January 8, 2017 Do as Xenith says! If you want a really bright blue like FW have you'll need to use a lot of the blue tint but it works perfectly! Link to comment https://bolterandchainsword.com/topic/329605-alpha-legion-which-colors-and-step/#findComment-4616603 Share on other sites More sharing options...
Major_Gilbear Posted January 9, 2017 Share Posted January 9, 2017 Actually, you can just buy a metallic dark blue paint to begin with - Vallejo Model Air "Arctic Blue" is exactly this, and it will save you a lot of time and money compared to Xenith's suggestion. It's also much more consistent for painting an army with. Oh, and despite the paint's name, you can use a normal brush with these "air" paints. (Here's a comparison of various different brands of blue metallic paint for you: link). Highlight by adding a silver to the Arctic blue (any silver of your choice). Shade by mixing a little blue and black ink together (about a 50/50 ratio - Vallejo sells acrylic inks too), and carefully apply this to the recesses. If you need to make the blue a bit more intense, or if you want to make it a bit green in places, thin an suitably-coloured ink with a little clean water, and apply over the whole area. Don't let this pool, and be aware that you may need a couple of layers to get the desired effect (especially if you are looking to add a green hint to the blue). One last comment: try the intended scheme over different primers before you commit to the models. I have a feeling a grey primer will work better for you than black, and that white might be a bit too bright. Either way, if you do a test, and apply a couple of coats of Arctic Blue over them, you'll know what you prefer. :) Link to comment https://bolterandchainsword.com/topic/329605-alpha-legion-which-colors-and-step/#findComment-4616778 Share on other sites More sharing options...
suxdavide Posted January 10, 2017 Author Share Posted January 10, 2017 I'm not super good at mixing (never did that) so I'll probably stick to the leadbelcher + tint hoping not to use too much. What about the primer, should I primer directly silver or white or black? Link to comment https://bolterandchainsword.com/topic/329605-alpha-legion-which-colors-and-step/#findComment-4618291 Share on other sites More sharing options...
CrimsonReign Posted January 10, 2017 Share Posted January 10, 2017 i would say black, even when priming silver it looks better over a black primer Link to comment https://bolterandchainsword.com/topic/329605-alpha-legion-which-colors-and-step/#findComment-4618319 Share on other sites More sharing options...
Major_Gilbear Posted January 10, 2017 Share Posted January 10, 2017 I'm not super good at mixing (never did that) so I'll probably stick to the leadbelcher + tint hoping not to use too much. That's why I suggested using a ready-made metallic blue paint; why mix your own? For shades and highlights, you are still going to need to do something, whatever method/colour you go for. I have provided suggestions and ratios above to help you. What about the primer, should I primer directly silver or white or black? As I suggested, you might want to spray a few spare bases and try painting over them in your colours. I think a grey will give you a nice mid-way point between giving the metal colour a good vibrancy/intensity and not showing up any areas you can't reach to paint; but the best thing to do it test it out and see what you think. Link to comment https://bolterandchainsword.com/topic/329605-alpha-legion-which-colors-and-step/#findComment-4618357 Share on other sites More sharing options...
suxdavide Posted January 16, 2017 Author Share Posted January 16, 2017 I just tried the tamiya's blue metallic and this is the output: http://imgur.com/a/4PZvo I like it, I just need to improve, as always, my painting and choose how to highlight. I'll surely, once I get the ones with pads etc, paint the details in moot green, the bolter instead with Incubi Darkness. http://i.imgur.com/8UYNYSO.png Link to comment https://bolterandchainsword.com/topic/329605-alpha-legion-which-colors-and-step/#findComment-4624689 Share on other sites More sharing options...
