Betrayal of Calth MkIV Marine arms
Trokair
Not sure if this is the best place to ask, so please do move if elsewhere is more appropriate.
I bought some MkIV marines out of the betrayal at Calth box. At the time I had a quick look at the assembly instruction and it all looked straight forward.
However now that I am building them it looks like the left and right arms are all paired. Could somebody tell me which numbers go together for the bolter arms, the heavy bolter arms and the special weapons arms?
Thank you
If you look at the arms, they have details on the inner forearm that are unique to each pair.
If you match these details up, left/right, you have a pair.
There's one set of detailing which has two slightly different right arms, which I think are the pair up to the face - this is because the plasma is slightly differently shaped.
I drew a small description next to the instructions - I can PM you a pic when I get home later?
Google is your friend... search Betrayal at Calth Assembly Guide.
I did, and I did find several pictures, which helped a little, but the numbers where hard/impossible to read.
The detail on the inner arm matching up, as Cloud Runner pointed out, is proving more helpful than what I found by googling.
Next time I buy part of a kit rather than all of it I'll take pictures of the instructions even if it looks self explanatory.
