Dremiah Posted January 27, 2017 Share Posted January 27, 2017 Could anyone point me to a good vid on assembly and paint off a land raider? Link to comment https://bolterandchainsword.com/topic/330323-land-raider-assemblage-and-painting/ Share on other sites More sharing options...
Khornate individual Posted January 28, 2017 Share Posted January 28, 2017 Don't know of any vids, but is there something your having trouble with on the assembly? Link to comment https://bolterandchainsword.com/topic/330323-land-raider-assemblage-and-painting/#findComment-4636625 Share on other sites More sharing options...
Dremiah Posted January 28, 2017 Author Share Posted January 28, 2017 Not particularly, I bought the Strike force ultima box, and in looking at the land raider sprues, I see there are pieces that will need painting on the inside of the model. So I was just simply wondering if there was a good tutorial on what/when to paint before or after final assembly. Link to comment https://bolterandchainsword.com/topic/330323-land-raider-assemblage-and-painting/#findComment-4636997 Share on other sites More sharing options...
Chaplain Raeven Posted January 28, 2017 Share Posted January 28, 2017 I had the same problem. I haven't found any guides for painting the interior. Most topics about the interior is about LED-lighting, so they skip the painting part. I assembled the interior of the landraider (Floor, engine, interior walls and doors), left the exterior armour off, masked the surfaces that will be glued and primed the whole thing. After everything was painted, I glued the exterior armour and roof and primed the exterior. Link to comment https://bolterandchainsword.com/topic/330323-land-raider-assemblage-and-painting/#findComment-4637010 Share on other sites More sharing options...
Khornate individual Posted January 29, 2017 Share Posted January 29, 2017 I primer and paint the whole interior before assembly. Just mask off areas that you don't want your primer on and primer all of the tank at the same time, that way you don't have to primer the outside of the tank after the inside is done. You don't want primer misting in on your painted interior. If you get primer or paint on any areas that need glued, use your x acto blade to clean it off and your good to go. Link to comment https://bolterandchainsword.com/topic/330323-land-raider-assemblage-and-painting/#findComment-4637339 Share on other sites More sharing options...
Ovidius Incertus Posted January 29, 2017 Share Posted January 29, 2017 Here's one that includes painting the interior before assembly. I've also seen others where they've said "never again" because the doors flop down while painting the exterior and ruin the interior paint. Link to comment https://bolterandchainsword.com/topic/330323-land-raider-assemblage-and-painting/#findComment-4637805 Share on other sites More sharing options...
Khornate individual Posted January 30, 2017 Share Posted January 30, 2017 Doors flop down while painting? Lousy assembly? Never had doors fall on a landraider, a rhino rear door is a different story. But if the doors "flop down", a little bit of masking tape will cure that problem while painting. Link to comment https://bolterandchainsword.com/topic/330323-land-raider-assemblage-and-painting/#findComment-4638552 Share on other sites More sharing options...
Golf33 Posted January 31, 2017 Share Posted January 31, 2017 I've found plastic cement works through primer and paint - at least Revell Contacta does. Link to comment https://bolterandchainsword.com/topic/330323-land-raider-assemblage-and-painting/#findComment-4639571 Share on other sites More sharing options...
Xenith Posted February 1, 2017 Share Posted February 1, 2017 I was just simply wondering if there was a good tutorial on what/when to paint before or after final assembly. Paint the inside before final assembly? Skip painting it if you glue the doors shut. Link to comment https://bolterandchainsword.com/topic/330323-land-raider-assemblage-and-painting/#findComment-4640649 Share on other sites More sharing options...
