2000pt Solar Auxilia
Lord Marshal - the Lord takes Blind Barrage giving all units shroud first turn, allowing them some cover to run.
4 20xman Infantry Tercio's. SGT's with Melta bombs
3x Vanquishers with HMLC's
3x Demolishers with HMHF's
1 Malcador Infernus with Chem Inferno Gun
Aegis Defense Line with Comms relay to help the Vanquishers arrive from outflank to target side armor and contest.
https://bolterandchainsword.com/topic/330335-2000pt-solar-auxilia/
I'd keep the Demolishers with heavy bolters, as the heavy flamers can't Snap Shoot after firing an Ordnance weapon.
Also, mix it up a bit! It's a very 1-dimensional list. Maybe you only need 3 Lasrifle Sections, each with their own Aegis (the other two can take Troop Masters and Quad Guns for some AA).
And a pair of Tank Commanders would add a lot to the Leman Russ Squadrons.
Good call Callium.  Thank you.  Changes below.
3 20xman Infantry Tercio's
3x Vanquishers with HMLC's - one upgraded to tank commander with tank hunter
2x Demolishers, 1x Executioner, all with HMHB's
1 Malcador Infernus with Chem Inferno Gun - upgraded to Command Tank - the Morale rerolls will be helpful
