Jarkaira Posted February 4, 2017 Share Posted February 4, 2017 I am trying to build a list for tournament coming later this year and the meta is somewhat semi-competitive with lists often tooled around X with Y in a Spartan often accompanied with Leviathan in a pod and a minimal amount of scoring units. I could try to counter this by running redundant amount of troops but whats the fun in that? If I could wreck the Spartan and Leviathan and leave their 1000pts melee unit in the middle of field and in graviton bubbles I could laugh up to my sleeves. So I have thought about this kind of a list. Praetor + power fist + Paragon blade + melta bombs + digital lasers + iron halo + Cyber-familiar + Scimitar Jetbike • 2 Space Marine Chosen + 2× power weapon + Scimitar Jetbikes + 1 Standard Bearer + power weapon 9 Veteran Space Marines + 3× combi-weapon + 4× power weapon + legion vexilla + plasma gun + 1 Veteran Sergeant + artificer armour + combi-weapon + power weapon • Rhino + dozer blade + pintle-mounted multi-melta 9 Veteran Space Marines + 3× combi-weapon + 4× power weapon + legion vexilla + meltagun + 1 Veteran Sergeant + artificer armour + combi-weapon + power weapon • Rhino + dozer blade 7 Tactical Support Marines + plasma guns + 1 Tactical Support Sergeant • Rhino + dozer blade + pintle-mounted multi-melta 3 Rapier Carriers + graviton cannon Primaris-Lightning Strike Fighter + 3× 2 wing-mounted Kraken penetrator heavy missiles + battle servitor control + ground-tracking auguries Land Speeder Squadron • Land Speeder + pintle-mounted multi-melta + hull-mounted graviton gun • Land Speeder + pintle-mounted multi-melta + hull-mounted graviton gun • Land Speeder + pintle-mounted multi-melta + hull-mounted graviton gun Sicaran Venator Tank Destroyer + dozer blade + armoured ceramite + 2 sponson-mounted lascannon Deredeo Pattern Dreadnought + carapace-mounted Aiolos missile launcher + armoured ceramite Vindicator Siege Tank Squadron • Vindicator + hull-mounted laser destroyer array + mine plough + Squadron Command Tank • Vindicator + hull-mounted laser destroyer array + dozer blade • Vindicator + hull-mounted laser destroyer array + dozer blade What do you guys think about this? Link to comment Share on other sites More sharing options...
Harrowmaster Posted February 4, 2017 Share Posted February 4, 2017 I wouldn't take a plasma gun and power weapons in the same veteran squad as you can't charge after firing Personally I wouldn't take a power fist and paragon blade on the praetor, too expensive Link to comment Share on other sites More sharing options...
Jarkaira Posted February 4, 2017 Author Share Posted February 4, 2017 Good points. Changed those parts. Praetor + thunder hammer + melta bombs + digital lasers + iron halo + Cyber-familiar + Scimitar Jetbike • 2 Space Marine Chosen + 2× power weapon + Scimitar Jetbikes + 1 Standard Bearer + power weapon 9 Veteran Space Marines + 4× combi-weapon + 4× power weapon + legion vexilla + 2× meltagun + 1 Veteran Sergeant + artificer armour + combi-weapon + power weapon • Rhino + dozer blade + pintle-mounted multi-melta 9 Veteran Space Marines + 8× power weapon + legion vexilla + 1 Veteran Sergeant + artificer armour + combi-weapon + power weapon • Rhino + dozer blade 7 Tactical Support Marines + plasma guns + 1 Tactical Support Sergeant • Rhino + dozer blade + pintle-mounted multi-melta 3 Rapier Carriers + graviton cannon Primaris-Lightning Strike Fighter + 3× 2 wing-mounted Kraken penetrator heavy missiles + battle servitor control + ground-tracking auguries Land Speeder Squadron • Land Speeder + pintle-mounted multi-melta + hull-mounted graviton gun • Land Speeder + pintle-mounted multi-melta + hull-mounted graviton gun • Land Speeder + pintle-mounted multi-melta + hull-mounted graviton gun Sicaran Venator Tank Destroyer + dozer blade + armoured ceramite + 2 sponson-mounted lascannon Deredeo Pattern Dreadnought + carapace-mounted Aiolos missile launcher + armoured ceramite Vindicator Siege Tank Squadron • Vindicator + hull-mounted laser destroyer array + mine plough + Squadron Command Tank • Vindicator + hull-mounted laser destroyer array + dozer blade • Vindicator + hull-mounted laser destroyer array + dozer blade Link to comment Share on other sites More sharing options...
Harrowmaster Posted February 4, 2017 Share Posted February 4, 2017 You have plenty of anti-tank but little anti-infantry would you consider changing the graviton cannons to quad mortars? You have very few scoring units which could seriously hurt you, especially at the 3000 level. It might be a good idea to try and find the points for an apothecary with an augury scanner to go with the support squad to increase their usefulness. Link to comment Share on other sites More sharing options...
montambro Posted February 4, 2017 Share Posted February 4, 2017 Also you could drop the lascannons on the venator. Since its ordinance they will only be able to snap fire. Link to comment Share on other sites More sharing options...
Rangaman Posted February 5, 2017 Share Posted February 5, 2017 Another thing to consider is the ratio of LA to non-LA, the format for your list is a bit messy but from a rough count you have more non-LA:LA which makes it illegal using PotL. Link to comment Share on other sites More sharing options...
