Field Police paint scheme
This paint scheme appeared in the news section, and looks ace.
http://i.imgur.com/PgtrzPe.jpg
I want to use that scheme for my blackshields. It looks simple, but something bothers me. I can't tell if it's a weathered mid grey or a very dull metal (the main armor, shoulderpads looks like eshin grey with a light black wash).
Any ideas on how to achieve the main color? Any tip will be nice.
https://bolterandchainsword.com/topic/330843-field-police-paint-scheme/
You could mix a dark-ish grey and a silver to get a dull lead-like colour? Some small "scratchy" feathered highlights, a little plain dark grey/black sponged on sparingly, some brown-orange streaks using a wash around rivets and such, some oily wash in the recesses, and then a final very thin crisp highlight here and there with a little light grey (or silver if you prefer) to pick out the faceplate and the most raised areas.
I know mixing metallic paints with regular paints isn't very common, but I've done it a lot and it's actually a great way to achieve these sorts of half-way schemes. :)
Thanks major. Will keep this for further use. The only time I mixed metal colors with non metal was to make a dark boltgun metal (which was chaos black & boltgun metal 50/50) but the result, even ok-ish, didn't ended as expected. I hate the metals because is difficult to make them to look like the real deal instead of painted plastic (however, later on I achieved some good results following a tutorial from Apologist) so I'm going to test it when I can :)
The nice thing about mixing them is that you can play with the reflectivity as well as the colour - so matte shadows and more reflective highlights for example. This means that even on a more even colour, as long as you shade and highlight a little to make use of the different finishes, you can get distinct yet subtle effects. :)
