Blackadder Posted February 15, 2017 Author Share Posted February 15, 2017 Okay so I had some 3/8 inch box beams (Plastruct) laying about so I used them as spacers to thicken the construction and give it strength to boot. Then if I need to modify it later it will be easier to sand down instead of a solid block. http://i.imgur.com/a8Qgxh0.jpg http://i.imgur.com/a8Qgxh0l.jpg http://i.imgur.com/FIQUh3s.jpg http://i.imgur.com/FIQUh3sl.jpg http://i.imgur.com/RwtL7aC.jpg http://i.imgur.com/RwtL7aCl.jpg http://i.imgur.com/LkzMGrT.jpg http://i.imgur.com/LkzMGrTl.jpg This all seems pretty boring and I hope to get into the fancy stuff soon. Right now giving this heavy model (My warlord upper body weighs seven pounds) a strong basic structure is paramount. Space Truckin 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4657090 Share on other sites More sharing options...
Col.hertford Posted February 15, 2017 Share Posted February 15, 2017 I've seen Emperors that were upwards of 5-6 foot tall and while big they were not impressive. The taller they are the more detail they require; what looks good on a two foot model looks barren and fake on a six foot model. A quick calculation gives 386 feet tall at 28 mm scale. It would dwarf any of the existing FW models to insignificance. My Luteus scales 160 feet tall at 27 inches plenty big in person believe me. More on the scale of an Imperator Titan........ According to Warhammer 40K Wikia: http://warhammer40k.wikia.com/wiki/Imperator-class_Titan "The Imperator and Warmonger Emperor Titans stand approximately 55.5 metres (182 feet) tall" and hold a company of infantry(I'm guessing about 200 troops?) Judging by the size of the greaves even on an Emperor, the grunts must be stacked up like cord wood. The old Titan legions game said the protection contingent was 30 per foot bastion. Another 30 in the body, then of course you would have the crew and sevitors. Here's a link to the data card. I think 90 skitarri would make a strong defence force, and considering the fact a warlord doesn't have any, a nice jump in scale. Will you add point defences too (ala the FW Warlord)? https://boardgamegeek.com/image/188794/titan-legions Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4657182 Share on other sites More sharing options...
Blackadder Posted February 16, 2017 Author Share Posted February 16, 2017 Thanks for the information and the Data Card (Not seen one of those before) also what are "Point Defenses"? As you can tell I don't play the game I just like building the hardware. My son is the gamer but he's in Las Vegas now or I'd ask him. Basic Pelvis Block Complete: With thsi post the basic pelvis is complete. All that is left is applying the detail. I may bevel the corners and edges to add more pizzazz as I did on the Thunderhawk but all that is cosmetic. http://i.imgur.com/zJQSzyE.jpg http://i.imgur.com/zJQSzyEl.jpg The Epic Imperator is very plain and you can let your imangination run wild with the amount of detail a 3 foot tall model requires. I have a good stock of City of Dead panels left over from my Warlord and I have a Fortress of Redemption to decorate the greaves if needs be. http://i.imgur.com/2oMX14M.jpg http://i.imgur.com/2oMX14Ml.jpg I used 0.040 thousandths styrene to sheath the pelvis and sanded the edges smooth; there's not really much to say about the step except to take great pains to make your angles square and true. Good enough is never "Good Enough"; that's my motto. http://i.imgur.com/PUPtHYJ.jpg http://i.imgur.com/PUPtHYJl.jpg A few extra pains taken now will save you a lot of grief later. http://i.imgur.com/Jp3YsLu.jpg http://i.imgur.com/Jp3YsLul.jpg Pyroclast91, Space Truckin and The Traitor 3 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4658204 Share on other sites More sharing options...
Blackadder Posted March 4, 2017 Author Share Posted March 4, 2017 Getting the right angle: I've wracked my brains trying to come up with a way to manufacture legs that were angled slightly akimbo (about 10%) so my Warmonger can be posed in the classic manner. Most of the pipe fitting models I have seen have the legs parallel to each other and it looks boxy and strange to the artistic eye. Never mind that parallel legs or even legs canted in to a pigeon toed stance are more amenable to a proper walking gate. For a static stance nothing compares to the rock solid look of a spraddled posture. This realized, getting the proper fittings is out. You have three choices; 90°, 45°, and 22.5° and that's it, so to get the requisite 10° I'll have to manufacture them. Here's my solution: I bought two caps and drilled and taped two 1/4 20 NC threads into the caps and short threaded coupling. I purposely made two different angles, one 10° and one about 12°, as once the legs are built I can chose which angle I like better or maybe keep both for a bit of variation. I screwed in two 6 inch threaded rods that will serve as the thigh shafts, thin and strong and able to support the ten pounds or more of the upper body when finished. http://i.imgur.com/tPwX9xN.jpg http://i.imgur.com/tPwX9xNl.jpg Next I slipped two styrene tubes over the threaded rods that will serve as the glue base for all the thigh shaft construction and ultimately the detail of the upper legs. http://i.imgur.com/TUygS3w.jpg http://i.imgur.com/TUygS3wl.jpg Your pardon for the hiatus but I took a last minute vacation for the past few weeks to clear my head and tour Florida. bluntblade 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4672928 Share on other sites More sharing options...
AngelsofCaliban Posted March 5, 2017 Share Posted March 5, 2017 Hi Blackadder, Long term follower of your work and thankyou for all the invaluable tips. Point defences on titans are very similar to the twin heavy bolter turrets on a space marine razorback or the small front turret above the front ramp on a landraider. How do you ensure thin plasticard is at right angles especially if both sides need to be exposed or due to space constraints cant have buttresses or small pieces glued in as support. Thanks in advance Aaron. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4673443 Share on other sites More sharing options...
Blackadder Posted March 5, 2017 Author Share Posted March 5, 2017 How do you ensure thin plasticard is at right angles especially if both sides need to be exposed or due to space constraints cant have buttresses or small pieces glued in as support. I ran into this problem when building the pelvis for this model. Fortunately the block was sufficiently large to use 3/8 inch square tube stock to reinforce the 90° degree angles. You can use any of the square stock available from Evergreen Styrene to reinforce the inside angles of your work. I use Plastruct Bondene plastic solvent cement for it's strength and fast drying capabilities now that Ambroid solvent is no longer available. The trick is to allow sufficient drying time before handling or resuming construction. Use rare earth magnets to clamp parts until dry (I demonstrate this technique later on) if there is insufficient room for 'C' clamps or bar clamps. Spring jawed Clothes pins are also useful in certain applications, I use them all the time. HTH. If you could be more specific with your problem I may be able to address it better. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4673548 Share on other sites More sharing options...
AngelsofCaliban Posted March 5, 2017 Share Posted March 5, 2017 Thanks for your fast reply and it answers my question. It seems I have been too hasty in resuming construction after glueing. I use square and angle stock a lot and looking forward to seeing how you use rare earth magnets. Also you may have answered or shown this before but I can't find it. When glueing 10 thou either for barrels or laminating plasticard to create more details how do you ensure a nice even panel sometimes it warps along the glue line and creates what looks like waves. I'm ok with 20thou but would like to use some 10 thou at other times. Do you use plastic putty at all sometimes it flakes off with sanding back or am i better off mixing shavings with plastic cement for plasticard repairs. Once again thanks in advance Aaron Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4673569 Share on other sites More sharing options...
Blackadder Posted March 5, 2017 Author Share Posted March 5, 2017 Thanks for your fast reply and it answers my question. It seems I have been too hasty in resuming construction after glueing. I use square and angle stock a lot and looking forward to seeing how you use rare earth magnets. Also you may have answered or shown this before but I can't find it. When glueing 10 thou either for barrels or laminating plasticard to create more details how do you ensure a nice even panel sometimes it warps along the glue line and creates what looks like waves. I'm ok with 20thou but would like to use some 10 thou at other times. Do you use plastic putty at all sometimes it flakes off with sanding back or am i better off mixing shavings with plastic cement for plasticard repairs. Once again thanks in advance Aaron I don't use putty because it looks sloppy and it's simpler to do the job cleanly than to try to sand it smooth and clean edged. (You know Blackadder, sometimes you're really a pain in the ass.) :D For 0.010 inches sheet stock I use 'old solvent' that has lost a lot of it's volatility . It gets weaker with age and doesn't dissolve the plastic so readily. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4673747 Share on other sites More sharing options...
Blackadder Posted March 6, 2017 Author Share Posted March 6, 2017 Thanks for the reply, Two Steps Back: Found these dynomite compression couplings that are just made for this construct so scrap the rods and the sleeve for the nonce and work on cropping the length of the assembly. http://i.imgur.com/rDXJWCH.jpg http://i.imgur.com/rDXJWCHl.jpg By cutting off the octagons I managed to crop the length by about 30 MM which makes the extreme width of the hips 12.5 inches (31.75 CM) compared to my Warlord's 10.5 inches (26.67 CM) which should be just right for a scale:180 to 200 ft (54 to 61 meter) tall Emperor Titan. http://i.imgur.com/bLFeR7p.jpg http://i.imgur.com/bLFeR7pl.jpg Space Truckin 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4675229 Share on other sites More sharing options...
Blackadder Posted March 8, 2017 Author Share Posted March 8, 2017 If you thought the Warlord was inspiration wait til you get a load of this. Oh God I'm In Love: Look what I just found! Before I started this I had so-so enthusiasm for this project thinking it's worth a shot making a easy to build Emperor Titan that my readers might attempt along with me but that stops now! I am totally jazzed about this project since I found this head. Back when I began my Warlord finding Dave Smith's Epic rendering committed me to the project. That is what finding this image has done. http://i.imgur.com/Y2qZ5Cv.png http://i.imgur.com/Y2qZ5Cvl.png Starting now I'm going to build this part full sized (as it prints out on Landscape 8.5 X 11 paper) and build the rest of the titan in proportion. The overall size is just about an inch bigger than my Warlord's head overall so it is in keeping with my projected height for my Emperor. This is going to be 'dynomite!' if I can accomplish it. SW1, Brother Aiwass, Lasuria and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4677537 Share on other sites More sharing options...
SickSix Posted March 8, 2017 Share Posted March 8, 2017 This gonna be good... Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4677565 Share on other sites More sharing options...
Blackadder Posted March 9, 2017 Author Share Posted March 9, 2017 Simple As Falling Off A Log: When I started this thread I said to myself, "I'm going to make this model as simply as I can just to see what can be done with off the shelf items readily available to the judicious builder. I planned this so anyone can make one of these along with me. http://i.imgur.com/57b5tEn.jpg http://i.imgur.com/57b5tEnl.jpg Here we have about $25 bucks worth of plastic pipe fittings, and model styrene. A $3.50 bottle of conditioner (We just need the bottle and a bit of imagination (Supplied by your's truly :D) and a fantastic head image to work off of, all you need is a cheap printer........ So with these parts gathered there should be no problem making the head and hip components. http://i.imgur.com/UM5Uizc.jpg http://i.imgur.com/UM5Uizcl.jpg The next part is a bit of a lark on my part; you're going to need an old beach chair. We've all seen them usually tossed in the rubbish with a broken hinge mechanism but usually two or three still functioning and all we need is two. http://i.imgur.com/PiTcJro.jpg http://i.imgur.com/PiTcJrol.jpg These will form working knee joints, I hope, with a bit of ingenuity. http://i.imgur.com/f5Z1vAb.jpg http://i.imgur.com/f5Z1vAb.jpg Of course it's not necessary to have flexing knees but since I have the chair I might as well go for the gusto. ;-) Space Truckin and SW1 2 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4678654 Share on other sites More sharing options...
Blackadder Posted March 10, 2017 Author Share Posted March 10, 2017 Neck: The coupling being PVC is not compatible with styrene so I applied a veneer of 0.015 sheet styrene so parts and detail can be added. http://i.imgur.com/ijcMkcJ.jpg http://i.imgur.com/ijcMkcJl.jpg I then roughed in the cutout coordinates for the head to neck connection. http://i.imgur.com/fI28OOL.jpg http://i.imgur.com/fI28OOLl.jpg The large round cylinder just below the helmet where the ears would be I am assuming is the neck/skull joint to allow the head to tilt down. Likewise the flexible conduits on either side of the chin. Why not call these by their anatomical names. The so-called "Command Bridge is very skull-like. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4679871 Share on other sites More sharing options...
Blackadder Posted March 10, 2017 Author Share Posted March 10, 2017 (edited) Jaw Cut Out: Using my vibrating saw it was a simple matter cutting out the jaw recess in the coupling. http://i.imgur.com/V33rgGl.jpg http://i.imgur.com/V33rgGll.jpg The neck is now ready for shaping and detailing. http://i.imgur.com/KoJVjmG.jpg http://i.imgur.com/KoJVjmGl.jpg Incidentally my Chicago Electric vibrating saw is a must have tool for hobbying; http://www.harborfreight.com/variable-speed-oscillating-multi-tool-62867.html This cut would be really difficult with virtually any other device other than a hand tool and my $25 dollar saw was a tremendous time saver. It took about five minutes to make this cut including the blade swap. Edited March 11, 2017 by Blackadder Space Truckin 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4679933 Share on other sites More sharing options...
Blackadder Posted March 14, 2017 Author Share Posted March 14, 2017 (edited) Snow Bound: So to while away the weather front I did some work on the neck which I have to admit is coming out better than expected. I sheathed the coupling on 0.040 thousandths styrene to three layers and then proceeded to bevel the rear edges 45° as in the drawing. http://i.imgur.com/Z9duybo.jpg http://i.imgur.com/Z9duybol.jpg As you can see below there is quite a bit of cutting to get the 45° bevel in the front edge ............ http://i.imgur.com/gZQcNh6.jpg http://i.imgur.com/gZQcNh6l.jpg but my 'Farmers file' was up to the task. http://i.imgur.com/BTujlxG.jpg http://i.imgur.com/BTujlxGl.jpg The forward bevel needs to be refined but is okay for the moment while I make the inner neck mechanism so the head can be tilted down. My previous Warlord has this capability but the mechanism is very clunky and I am hoping to refine it on this model. http://i.imgur.com/TbMVdfC.jpg http://i.imgur.com/TbMVdfCl.jpg Finally I found this collar that will work very well in the scheme I have in mind for the side to side movement of the head and fits into the Emperor design quite well. http://i.imgur.com/Ofba1Op.jpg http://i.imgur.com/Ofba1Opl.jpg Can anyone guess the source of this wondrous bit of sculpting? Edited March 14, 2017 by Blackadder MordentHex 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4684172 Share on other sites More sharing options...
binary Posted March 14, 2017 Share Posted March 14, 2017 Pot noodle? Or the equivalent own brand version Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4684241 Share on other sites More sharing options...
Blackadder Posted March 15, 2017 Author Share Posted March 15, 2017 Pot noodle? Or the equivalent own brand version Close, a 5.3 ounce Shoprite yogurt container. I plan to use a lot of recyclable plastic in the manufacture of this model.How well I succeed remains to be seen. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4684891 Share on other sites More sharing options...
OutlawSixActual Posted March 15, 2017 Share Posted March 15, 2017 Just absolutely inspiring how you see components of god-machines of death out of other peoples' refuse. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4684946 Share on other sites More sharing options...
Blackadder Posted March 16, 2017 Author Share Posted March 16, 2017 2D vs 3D I'm getting way ahead of myself with this head assembly so I put the brakes on to pitch an update. After scraping my initial idea of how the head assembly can tip forward on the neck I came up with this solution which will give me a lot more cockpit room for the crew. There also is a poetic license taken by the artist who drew the front and side reliefs of the Command Bridge. The huge ear discs that contain the head tilting mechanism cannot function as drawn and are of different sizes in the drawing. Never mind though, I have a solution. I'll start with cutting the forward neck ring to allow the discs to mount flat to the sides of the neck. http://i.imgur.com/mvwGHMu.jpg http://i.imgur.com/mvwGHMul.jpg Carving out an outer race for the gimbal head mount pad and gluing on the gimbal bases is what is shown here. The two 0.040th inch discs are 71 MM apart and 56 MM in diameter. http://i.imgur.com/gkvcxbH.jpg http://i.imgur.com/gkvcxbHl.jpg The bridge truss maintains the distance and keeps the gimbals square to each other and stabilizes the bases http://i.imgur.com/uFbVKve.jpg http://i.imgur.com/uFbVKvel.jpg Bottom view showing the forward ring carved out to accommodate the gimbal bases. http://i.imgur.com/ZpFupBN.jpg http://i.imgur.com/ZpFupBNl.jpg Next, the manufacture of the gimbals mounts. (The area left black in the 2D drawing.) Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4686465 Share on other sites More sharing options...
Studio Silvernale Posted March 17, 2017 Share Posted March 17, 2017 Man I want to build a titan now.... Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4687114 Share on other sites More sharing options...
maverike_prime Posted March 17, 2017 Share Posted March 17, 2017 Man I want to build a titan now.... Following BlackAdder's work logs does tend to have that effect. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4687130 Share on other sites More sharing options...
Blackadder Posted March 17, 2017 Author Share Posted March 17, 2017 Ha! Thanks for the replies, Gimbals: Or Trunnions whatever, These truncated discs will support the head on the neck to allow it to look down in a purely theatrical way as a downward pointing camera would be just as effective but the menace of this skull staring down at it's victim is too good to pass up. http://i.imgur.com/TxBpE0G.jpg http://i.imgur.com/TxBpE0Gl.jpg Above; the disc is a simple truncated construct featuring two circles 45,0 and 54,0 MM separated by 2,0 MM by 4,8 MM styrene spacers. http://i.imgur.com/fIfj5Yf.jpg http://i.imgur.com/fIfj5Yfl.jpg Unfortunately I got the angle wrong so I have to re-sheath the bevel but that's not a big deal. http://i.imgur.com/J7JtoOQ.jpg http://i.imgur.com/J7JtoOQl.jpg Tomorrow I hope to be working on the cockpit. Lasuria 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4687859 Share on other sites More sharing options...
Blackadder Posted March 18, 2017 Author Share Posted March 18, 2017 (edited) The Visor: Allowing for the helmet I mounted the gimbals with extended visor mounts made of 0.015 thousandths sheet styrene. As I don't really have a plan for the cockpit, chin or gullet piece all this is subject to change but at least now I understand how the cheek pieces work with the gimbals. http://i.imgur.com/dybKoJX.jpg http://i.imgur.com/dybKoJXl.jpg I suppose the best thing is to cut the helmet to see where it falls in relation to the ears (gimbals) and the amount of clearance required to allow the head to lower and raise. http://i.imgur.com/LEecGev.jpg http://i.imgur.com/LEecGevl.jpg Somehow I managed to guess right which moving part eclipses which and for that I am grateful. http://i.imgur.com/a8ra21q.jpg http://i.imgur.com/a8ra21ql.jpg Later on this evening I'll cut the helmet but I need to relax a bit after this thoroughly draining exercise in design. Martini Time!!!!! Edited March 18, 2017 by Blackadder Lasuria 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4688706 Share on other sites More sharing options...
maverike_prime Posted March 19, 2017 Share Posted March 19, 2017 Neck: The coupling being PVC is not compatible with styrene so I applied a veneer of 0.015 sheet styrene so parts and detail can be added. http://i.imgur.com/ijcMkcJ.jpg http://i.imgur.com/ijcMkcJl.jpg Question for ya, BlackAdder. If the Styrene and PVC are not compatible, what do you use to afix the styrene sheet to the pvc pip? Superglue? Or something else? Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4689195 Share on other sites More sharing options...
Blackadder Posted March 19, 2017 Author Share Posted March 19, 2017 Question for ya, BlackAdder. If the Styrene and PVC are not compatible, what do you use to afix the styrene sheet to the pvc pip? Superglue? Or something else? The glue I use won't melt the two materials together but since the styrene sleeve completely encases the PVC fitting there is sufficient surface area to stabilize the the glued connection. There are many times I have employed this method with satisfactory results. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/2/#findComment-4689271 Share on other sites More sharing options...
