maverike_prime Posted March 19, 2017 Share Posted March 19, 2017 Question for ya, BlackAdder. If the Styrene and PVC are not compatible, what do you use to afix the styrene sheet to the pvc pip? Superglue? Or something else? The glue I use won't melt the two materials together but since the styrene sleeve completely encases the PVC fitting there is sufficient surface area to stabilize the the glued connection. There are many times I have employed this method with satisfactory results. So you use the same type of plastic glue you would normally use? Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4689389 Share on other sites More sharing options...
Blackadder Posted March 20, 2017 Author Share Posted March 20, 2017 The Same. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4690467 Share on other sites More sharing options...
Blackadder Posted March 22, 2017 Author Share Posted March 22, 2017 Helmet: My initial thought was to use a suitably shaped bottle to form the helmet but after experimentation I found that was unsatisfactory for my obsessive compulsive mindset. I opted instead for building up the helmet out of stratified layers of styrene and cutting the helmet out of the resulting block in much the same manner as I did for my Warlord Titan http://i.imgur.com/gxEB51B.jpg http://i.imgur.com/gxEB51Bl.jpg This also relieves me of the necessity of finding a suitable glue for mating the different sources of plastic...... http://i.imgur.com/uAIDHK3l.jpg http://i.imgur.com/uAIDHK3l.jpg It's bad enough that I had already go through the identical thought processes in making my Warlord but to have not learned for my previous effort defies logic. :( Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4691898 Share on other sites More sharing options...
Blackadder Posted March 24, 2017 Author Share Posted March 24, 2017 Ready To Begin Shaping: The layering is complete and all needs be done is the shaping http://i.imgur.com/aK44D0O.jpg http://i.imgur.com/aK44D0Ol.jpg I made the helmet about an eighth inch over sized per inch to allow for carving and sanding http://i.imgur.com/axEuWUo.jpg http://i.imgur.com/axEuWUol.jpg Tomorrow I should be well along on the paring down to the rough dimensions. http://i.imgur.com/l0WOVlJ.jpg http://i.imgur.com/l0WOVlJl.jpg Space Truckin 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4694614 Share on other sites More sharing options...
Blackadder Posted March 25, 2017 Author Share Posted March 25, 2017 First and Second Contour Cuts: Most of which are done on a stationary belt sander. http://i.imgur.com/7RO8KiC.jpg http://i.imgur.com/7RO8KiCl.jpg One more preliminary contour cut to make..... http://i.imgur.com/SVQpT3F.jpg http://i.imgur.com/SVQpT3Fl.jpg The sides have to be rough sanded at about 45° before the finishing contour sanding. http://i.imgur.com/VYPbiO9.jpg http://i.imgur.com/VYPbiO9l.jpg Radiation 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4695247 Share on other sites More sharing options...
Blackadder Posted March 26, 2017 Author Share Posted March 26, 2017 Rough Shaping: Final rough shaping involves truing up the block to 90° then cutting a 45° bevel each side and finally two 22.5° bevels each side on top and sides. http://i.imgur.com/9DUyTiT.jpg http://i.imgur.com/9DUyTiTl.jpg Next (and this is the tricky part because it takes a bit of an eye for roundness) sanding off the excess in a controlled arc movement on the sanding belt. http://i.imgur.com/bdNKxBZ.jpg http://i.imgur.com/bdNKxBZl.jpg http://i.imgur.com/8vAqAXM.jpg http://i.imgur.com/8vAqAXMl.jpg http://i.imgur.com/W0ZiUMI.jpg http://i.imgur.com/W0ZiUMIl.jpg so the helmet has a slightly flattened ovoid shape in cross section. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4696038 Share on other sites More sharing options...
Blackadder Posted March 28, 2017 Author Share Posted March 28, 2017 Basic Helmet and Head Well it took far more time than I thought but I do finally have the basic helmet cut to size. http://i.imgur.com/P1eCper.jpg http://i.imgur.com/P1eCperl.jpg http://i.imgur.com/fNkomQv.jpg http://i.imgur.com/fNkomQvl.jpg http://i.imgur.com/J6b7rWg.jpg http://i.imgur.com/J6b7rWgl.jpg http://i.imgur.com/5egDBeZ.jpg http://i.imgur.com/5egDBeZl.jpg The rear view shows how much I cut out of the interior so I can add the under helmet detail when the cockpit is complete. I may still remove a lot of the inside material but for now it's sufficient as the helmet is as fragile as an eggshell with out it's interior framing. http://i.imgur.com/n4znz4T.png http://i.imgur.com/n4znz4Tl.png BTW you may have noticed the background image. This is what I am hoping the finished Titan will look like but leaner and longer legs. The Traitor, Noserenda and Chaplain Raeven 3 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4697711 Share on other sites More sharing options...
Blackadder Posted March 30, 2017 Author Share Posted March 30, 2017 (edited) Suffice it to say I am not happy how this helmet is turning out so I am revamping it. Update coming soon. Meanwhile: I naturally assumed my Warlord crew would fit into an Imperator head but never really checked so while I'm waiting to complete the face shield I just tried them for size..... There's plenty of room; even for a Princep and a few attendees And a cadre of Tech Priests as well. http://i.imgur.com/Hgx7B75.jpg http://i.imgur.com/Hgx7B75l.jpg http://i.imgur.com/ApSGtc4.jpg http://i.imgur.com/ApSGtc4l.jpg Edited March 30, 2017 by Blackadder Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4699609 Share on other sites More sharing options...
Blackadder Posted April 3, 2017 Author Share Posted April 3, 2017 Now It Can Be Told: Now that I have resolved the issue I can reveal why I had to revamp the helmet. It all boiled down to an assumption on my part that the artist drawing the two elevations of the head was a draughtsman. In a proper draught you project lines from one plane to another and ideally there should be a top elevation as well but I accepted the two elevations as sufficient for my 3D rendering. I built my model slightly oversized than the plan as I wanted the 'head' to be larger than my Warlord's head as the finished model will be 10 to 12 inches taller than my Warlord. I blissfully used the side elevation for all my calculations and after laminating all the layers proceeded to sand the contours of the helmet but after the rough sanding was completed I found the helmet dome was significantly flattened. http://i.imgur.com/8vAqAXM.jpg http://i.imgur.com/8vAqAXMl.jpg It did not have the look of the front elevation at all. Needless to say I was extremely disappointed as I had based my interior design and mechanism on the front projection...... http://i.imgur.com/56WnEFl.jpg http://i.imgur.com/56WnEFll.jpg Rather than scrap the helmet and start afresh I opted to build on the original to increase the height of the dome which is seen in these to images. It was last night that I managed to glue in the compound curved pieces requisite to obtain a smooth contour; the final pieces to be installed later this morning. http://i.imgur.com/2QebzHA.jpg http://i.imgur.com/2QebzHAl.jpg So with this setback resolved I can continue with the building of the head; my obsessive compulsive integrity intact. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4702465 Share on other sites More sharing options...
Lord_Ikka Posted April 3, 2017 Share Posted April 3, 2017 Very ambitious. Keep up the great work! Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4702470 Share on other sites More sharing options...
Blackadder Posted April 4, 2017 Author Share Posted April 4, 2017 A Cure for a Rainy Day: After a rough rounding sanding I scored the armour panel lines. First with my utility knife. Then with razor saw and finally with xacto keyhole saw blade https://www.widgetsupply.com/mm5/graphics/00000001/x-acto-x215-5pc-no-15-keyhole-saw-2016-main_519x340.jpg to widen the gaps between the armour http://i.imgur.com/rer2DpT.jpg http://i.imgur.com/rer2DpTl.jpg Now the helmet is ready for wet sanding which will hopefully remove the striation lines. http://i.imgur.com/Vuhruvo.jpg http://i.imgur.com/Vuhruvol.jpg http://i.imgur.com/iKwkjcl.jpg http://i.imgur.com/iKwkjcl.jpg Now we're back to making the visor. Chaplain Raeven and Grotsmasha 2 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4703337 Share on other sites More sharing options...
Blackadder Posted April 5, 2017 Author Share Posted April 5, 2017 Crest: The crest seemed a daunting task but after the helmet it was child's play. I began by laminating six layers of 0.030 thousandths styrene last night because 1/4 inch styrene is too expensive and to hard to work with plus 0.030 is what I had on hand. I then scribed two lines and equa-spaced the drill points with my vernier calipers. I used my #11 Xacto blade to deepen the drill points and hand drilled 1/16" pilot holes for the scallops. http://i.imgur.com/I6LWbhV.jpg http://i.imgur.com/I6LWbhVl.jpg Then I drilled 1/8 inch holes to center the 1/4 inch final holes for the scallops. http://i.imgur.com/shluvZ1.jpg http://i.imgur.com/shluvZ1l.jpg After drilling the 1/4 inch holes I cut off the excess material and sanded to the appropriate half hole depth. http://i.imgur.com/5ugL5iz.jpg http://i.imgur.com/5ugL5izl.jpg Magos Takatus, Cpt. Bannockburn, Space Truckin and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4704768 Share on other sites More sharing options...
PeaceCraft Posted April 6, 2017 Share Posted April 6, 2017 maaan i love the craftmanship in your super builds! stacking plastic and sanding is quite tough.Have you tried sculpting in putty to make these large volumes? cheap plumbers putty then cutting excess, dunno what way is faster cant wait to see more! cheers Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4704838 Share on other sites More sharing options...
Sgt. Blank Posted April 6, 2017 Share Posted April 6, 2017 Amazing work as always Blackadder. The method for the crest is clever and the result looks great. Keep it up! Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4704877 Share on other sites More sharing options...
Blackadder Posted April 6, 2017 Author Share Posted April 6, 2017 (edited) maaan i love the craftmanship in your super builds! stacking plastic and sanding is quite tough. Have you tried sculpting in putty to make these large volumes? cheap plumbers putty then cutting excess, dunno what way is faster cant wait to see more! cheers Every time I try a shortcut I come to regret it. Plumbers putty, resin, foam filled poster board, PVC pipe what-have-you all seem like good ideas but nothing beats using exclusively styrene for compatibility and longevity of glue seams plus repair and modification is so much easier for example; I built the helmet up of sheets of styrene, tedious task at best but found after sanding I had miscalculated int he height of the dome. Were I to have used a sculpting medium I would not have been able to add to the helmet plus you do not have the compatibility of the putty to styrene glue so adding fine detail would be difficult. But thank you for the suggestion. It is much appreciated. Edited April 6, 2017 by Blackadder Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4705236 Share on other sites More sharing options...
Blackadder Posted April 8, 2017 Author Share Posted April 8, 2017 Spear Heads: Spear Head ornaments are tedious but worth the effort. There are probably easier ways to make them but I want mine to have a 3D bas-relief so I made mine out of 0.040 thousandths styrene. Below we see one in place on the helmet and the rest in various states of manufacture. When doing something like this I allows make a few extra so I don't have to start from scratch. You never know when you might need a spare. Start by making an undersized template (marked 'T'), trace the points on a piece of scrap styrene, cut them out with scissors (yeah it's that simple,) Drill your pilot holes, Cut the corner holes with your; surgical diagonal cutters, Fingernail cutters, Dikes, what-have-you, use your rat tail needle files to make the spade base compare you work to the finished and make the proper adjustments with you, curved nail file and you're done. http://i.imgur.com/fFxZ4If.jpg http://i.imgur.com/fFxZ4Ifl.jpg Now do it twelve more times or more........ http://i.imgur.com/84L1tlJ.jpg http://i.imgur.com/84L1tlJl.jpg See you tomorrow. Grotsmasha 1 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4706630 Share on other sites More sharing options...
Blackadder Posted April 8, 2017 Author Share Posted April 8, 2017 Bada ba ba baaaa I'm Lovin' It: Funny how these ungainly projects grow on ya. At first I was mildly interested in this project. A lot of people requested I give it a go so for the past few years I accumulated various plastic bitz that looked like they might go on a quicky Imperial Titan that anyone sufficiently motivated could build. I still have baskets of the junk; bottlecaps recyclable containers and the like and I finally solved the pelvis dilemma but until I saw the head for lack of a better term I had little enthusiasm feeling that I had reached the pinnacle of Titan manufacture in my Warlord. http://i.imgur.com/hvfBsqo.jpg http://i.imgur.com/hvfBsqol.jpg Now I am in a quandary because this Titan will eclipse my previous effort but Damn I am getting really fond of this beastie. http://i.imgur.com/izMrl2e.jpg http://i.imgur.com/izMrl2el.jpg The front view shows up on the image more so than in person that the spearhead gusset on the right side is longer than that corresponding one on the left. that will have to be fixed but overall I am pleased with the outcome. I made my darts a tad larger than that in the computer image as I couldn't translate the drawing into an actual model. But it seems close enough and even as I write this I get the depression of compromise. http://i.imgur.com/jRCmP0p.jpg http://i.imgur.com/jRCmP0pl.jpg But no; that way madness lies. and it's still two hours to Martini Time... Dang! Chaplain Raeven and Lasuria 2 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4707000 Share on other sites More sharing options...
Col.hertford Posted April 8, 2017 Share Posted April 8, 2017 You deserve the Martini today! Inspirational stuff! Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4707014 Share on other sites More sharing options...
Blackadder Posted April 9, 2017 Author Share Posted April 9, 2017 The Perfection of Asymmetry: When you look at the Darth mask you are thrilled with the evilness of the visage but split the image and reverse it mirror image wise and you will see the resulting perfect symmetry of either the left or right is not nearly as disturbing. We are all different people when we see ourselves in a photograph. With the magic of the computer we can splice together the left and right images of our face and see two entirely different people neither recognizable as ourselves. http://i.imgur.com/N07NveX.jpg http://i.imgur.com/N07NveXl.jpg That is where I am with this visor. That and the printout I made is too small. The 0.030" plastic cutout I made directly below the helmet assembly seems to be of the correct size. Also the visor wraps around the helmet so the front view is foreshortened therefor I must allow for that by adding what i estimate a quarter inch (6,3 MM) to each side........ Fun and games, Right? Space Truckin, MordentHex and Sgt. Blank 3 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4707511 Share on other sites More sharing options...
Radiation Posted April 9, 2017 Share Posted April 9, 2017 Emperor guide thee. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4707740 Share on other sites More sharing options...
Sgt. Blank Posted April 10, 2017 Share Posted April 10, 2017 I didn't quite understand what the 'spear tip' shapes were for when you were making them but they look great installed. I can see doing something similar to make chaos iconography - thanks for the walk through Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4707748 Share on other sites More sharing options...
Blackadder Posted April 10, 2017 Author Share Posted April 10, 2017 Facial Planes: We're going to experiment with this visor as I don't have an overhead projection so I made the angle gussets flexible until I see how the 'face shapes up. http://i.imgur.com/9ysjqn4.jpg http://i.imgur.com/9ysjqn4l.jpg That way I can make the minimal adjustments required for an approximation of the artist's intent. http://i.imgur.com/Qc99a8q.jpg http://i.imgur.com/Qc99a8ql.jpg Note the strips in the foreground. The one with the heavy pencil line glues to the inner surface of the visor. It is slightly scored so it acts as a hinged gusset. It can sustain a minimum of flexing before fatiguing the same as the visor plate. Once I am satisfied with the position of the visor planes I'll reinforce the the back side of the visor to hold the shape. brettfp, The Traitor and GeofreyShank 3 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4707786 Share on other sites More sharing options...
Blackadder Posted April 10, 2017 Author Share Posted April 10, 2017 Raising the Ears: When I was a kid going to the barber was called, "having your ears lowered." Well in this case the operative word is raised. and bring the ears forward and shorten the helmet. BTW after having been to the barber, you had "White walls." http://i.imgur.com/AeNn6yB.jpg http://i.imgur.com/AeNn6yBl.jpg Anyway this side view projection shows I need to cut the helmet a minimum of 6 MM (one quarter inch) on each side and shorten the length almost half an inch (13,0 MM) which necessitates re-positioning the spear points. http://i.imgur.com/eNjbnNv.jpg http://i.imgur.com/eNjbnNvl.jpg Or I may just go with three after the one in the forehead. http://i.imgur.com/8stjVq5.jpg http://i.imgur.com/8stjVq5l.jpg The close up also doesn't do it for me; Fah! http://i.imgur.com/xa0CkQU.jpg http://i.imgur.com/xa0CkQUl.jpg paulJam, Othniel's Blade and brettfp 3 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4708176 Share on other sites More sharing options...
Blackadder Posted April 12, 2017 Author Share Posted April 12, 2017 Family Portrait: Who's your Daddy? I accomplished a whirlwind revamp of the Command Deck aka the 'Head' shortening the rear overhang (Wait, he is talking about the head of this beastie not the loo???) but I did leave the cock's comb alone. (he is talking about the loo!) Seen here along side my Warlord to give a proper scale. http://i.imgur.com/NvG8rtI.jpg http://i.imgur.com/NvG8rtIl.jpg And a closeup. http://i.imgur.com/tZgfEjR.jpg http://i.imgur.com/tZgfEjRl.jpg More images to come............ The Traitor, Space Truckin, brettfp and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4709751 Share on other sites More sharing options...
Blackadder Posted April 12, 2017 Author Share Posted April 12, 2017 Whoops: Seems I may have miscalculated on the size of the Titan. That face is huge compared to the Warlord. Of course I had planned upwards of 36 inches ( 0.9144 meters )but I had hoped to keep it under 33 inches (0.8382 meters ) just so it didn't relegate my Warlord to a minor player. This may not be the case now. http://i.imgur.com/928kBV1.jpg http://i.imgur.com/928kBV1l.jpg The front view in my estimation is spot on and I shall proceed with the styrene version and make the cutouts on the basic structure. Once I am satisfied with the overall size relationship of the various parts of the 'face' I'll make the details. http://i.imgur.com/MBwgT4X.jpg http://i.imgur.com/MBwgT4Xl.jpg The side view doesn't look quite right as there is too much forward projection with the cardboard template. When rendered in styrene wot the extra cheek plates added all will line up as it is supposed to...... At least that is my expectation. Link to comment https://bolterandchainsword.com/topic/330905-blackadders-attempt-to-build-a-lucius-patten-imperator/page/3/#findComment-4710027 Share on other sites More sharing options...
