Open ended points value Vlka Fenryka
Hello, unless there is a hard cap on Command squads, the VIth Legion should be able to go safely above the currently though of HQ limit cap of three HQ units.
Here's what I would build, some of it I have:
HQ
Praetor
Aether rune armor
(Other options to taste)
Priest of Fenris: Speaker of the dead
( or, if able, start the HQ shenanigans with Command squads, 1 per further 1,000 points)
Command squad, take as many as needed, per possible option to just add more as the points go up
Elites
Tartaros TDA, up to 15, I may either use Cataphractii to up this;
2 Spartans available to me right now
I think I have about three to five contemptors
Troops
Here's my current points sink,
Grey slayers x 10, each with BG, BP, ccw and unbuilt WGPL (what is the 30k name?)
X 6 (60 grey slayers)
Fast Attack
Assault squads to taste (I will make my own packs of Mk. III with Mk. VII jump packs if I need to)
Heavy Support
Long Fangs x 3 packs, unsure of weapons and full pack load outs right now
Lord of War
Fell blade in production
A points total of all this, even a range, would help; also as hoped, one HQCommand squad per every 1,000 after say 2 or 3,000.
Thoughts, points total, and feedback please?
And Thanks, if anyone can help answer this question.
Edit: cap of points should be 8,000 seeing as three master of the legion HQ choices allow three Command squads, plus Russ, plus Wolfkin.
There really is no cap the rules as written say must take an HQ per 1000 points regardless of force organization chart restrictions. While you mat take command squads you are also free to fill it with anything else as long as you don't exceed 1 master of the Legion per 1000 points.
