Quixus Posted February 23, 2017 Share Posted February 23, 2017 For the question whether an IC ceases to be a one model unit when he joins another unit, saying the IC is a one model unit makes the joining pretty pointless, but that is what the rules say. I wouldn't play it that way. Concerning a TDA IC joining a non-TDA unit, the IC becomes part of the unit he joined not the other way around. Neither the IC rule nor any other rule that I am aware of say that the unit loses the property of not being a TDA unit, so the unit still is a non-TDA unit. I'm pretty sure this is not what FW intended, and will possibly fix it, but right now it works. It is similar to the initial version of Cataphractii armour. Link to comment https://bolterandchainsword.com/topic/331058-space-wolves-hit-and-run/page/2/#findComment-4664124 Share on other sites More sharing options...
Lord Blackwood Posted February 23, 2017 Share Posted February 23, 2017 Hit and Run for all the things ( till it gets patched ) Link to comment https://bolterandchainsword.com/topic/331058-space-wolves-hit-and-run/page/2/#findComment-4664141 Share on other sites More sharing options...
BLACK BLŒ FLY Posted February 24, 2017 Share Posted February 24, 2017 · Hidden by Slips, February 24, 2017 - No reason given Hidden by Slips, February 24, 2017 - No reason given I can just imagine the conversation at the table..."Ok I'm going to H&R with my terms...""But.... the RoW says they can't.""But... there's this loop hole." "So you're telling me your that guy." Link to comment https://bolterandchainsword.com/topic/331058-space-wolves-hit-and-run/page/2/#findComment-4665446
SkimaskMohawk Posted February 24, 2017 Share Posted February 24, 2017 · Hidden by Slips, February 24, 2017 - No reason given Hidden by Slips, February 24, 2017 - No reason given "You're that guy" "But...this is how USRs work in every case where it says 'if one model in the unit has it' " "Cheater WAACTFG" "But...you did the same when your chaplain gave your squad fearless" "I'M POSTING ON THE INTERNET ABOUT YOU" Link to comment https://bolterandchainsword.com/topic/331058-space-wolves-hit-and-run/page/2/#findComment-4665571
Runefyre Posted February 24, 2017 Share Posted February 24, 2017 After re-reading the rule, it explicitly says that infantry units not equipped with terminator armour gain the H&R special rule. It doesn't disallow Terminator infantry to H&R, just that they don't gain the special rule. So when an independent character joins their squad (a speaker for instance), the terminators would gain Fearless, Preferred Enemy (Infantry), and Hit and Run because all those rules are "conferable" (as in the wording of the rule states that only one model in the unit needs to have the rule for all models in the unit to gain it). Does that abide by the fluff? Apparently not considering what the Bleed and Harry special rule says. Is there a way to get around the restriction? Yes, it is a completely legal tactic. Just not one I will use, specifically with cataphractii. I will use the tactic on tartaros, because I think it makes sense. Link to comment https://bolterandchainsword.com/topic/331058-space-wolves-hit-and-run/page/2/#findComment-4665590 Share on other sites More sharing options...
BLACK BLŒ FLY Posted February 24, 2017 Share Posted February 24, 2017 It should work for Tartaros for sure. Link to comment https://bolterandchainsword.com/topic/331058-space-wolves-hit-and-run/page/2/#findComment-4665629 Share on other sites More sharing options...
Withershadow Posted February 24, 2017 Share Posted February 24, 2017 Really the debate should have ended with that a couple of pages ago. Rules allow it, but it doesn't make sense on Cataphracts, so the "gentlemanly" option is to not break fluff and use Tartaros. I would have no issue with that, and that's coming from someone who is still conflicted about using Cataphracts in Rites that don't allow Slow&Purposeful. Link to comment https://bolterandchainsword.com/topic/331058-space-wolves-hit-and-run/page/2/#findComment-4665711 Share on other sites More sharing options...
BLACK BLŒ FLY Posted February 24, 2017 Share Posted February 24, 2017 · Hidden by Slips, February 25, 2017 - No reason given Hidden by Slips, February 25, 2017 - No reason given SW have a bad enough rep as is and this doesn't really help. Link to comment https://bolterandchainsword.com/topic/331058-space-wolves-hit-and-run/page/2/#findComment-4665822
sturguard Posted February 28, 2017 Share Posted February 28, 2017 I guess my opinion based around the models and the impact the rules would have. My first thought is this, how many units really can make use of hit and run that the SW have access to, where it would have much impact on the game. In my opinion, only say a 20 man GS blob. A 10 man squad often is going to be killed or crippled in combat. So from that perspective maybe the designers thought of this. A unit of terminators having hit and run certainly doesn't break the game and its certainly not better than some of the other rules/units FW has come up with. Perhaps its part of the reason the SW terminators are overpriced as they have the option to gain hit and run with one of the RoW? It's certainly not that hard to imagine. Link to comment https://bolterandchainsword.com/topic/331058-space-wolves-hit-and-run/page/2/#findComment-4668628 Share on other sites More sharing options...
Grimtooth Posted March 13, 2017 Share Posted March 13, 2017 It seems pretty clear; Pale Hunters grants the H&R USR with a specific exclusion. If you attach an non-terminator equipped model to a unit in TDA and attempt to grant them the USR, you are breaking the exclusion set by the RoW. Just look at it as the RoW is granting a specific version of the H&R USR because of the exclusion and it works out just fine. Unless your whole intent is to circumvent the RAW of the RoW to get H&R on terminator equipped infantry in which case you are being :cuss. Link to comment https://bolterandchainsword.com/topic/331058-space-wolves-hit-and-run/page/2/#findComment-4682098 Share on other sites More sharing options...
