Purge the Daemon Posted February 16, 2017 Share Posted February 16, 2017 I like primarchs and I like deathstars so those generally feature in my lists. The command Rhino is of questionable use but it's a cheap HQ and maybe the bombardment makes some points back its -1 to Reserves and deep strike aura can't hurt either I guess. Primary Detachment: Age of Darkness Legion: Vlka Fenryka LOW: Leman Russ 455 -Warlord -The Pale Hunters HQ: Hvarl Red-Blade 210 Priest of Fenris 145 -speaker of the dead -aether rune armour -great frost blade Damocles Command Rhino 100 Troops: 10 Varagyr 545 -10 frost claws -7 power fists -3 chain fists Spartan 375 -armoured ceramite -flare shield -dozer blade 10 Veterans 185 -artificer armour -power fist Rhino 40 -dozer blade 10 Veterans 185 -artificer armour -power fist Rhino 40 -dozer blade Fast Attack: 2 Javelins 130 -2 multi meltas 2 Javelins 130 -2 multi meltas Primaris Lighting 230 -4 kraken penetrators -battle servitor control -ground tracking auguries Heavy Support: Fire Raptor 230 -reaper autocannons -hellstrike missiles Link to comment Share on other sites More sharing options...
Lord Howling Posted February 17, 2017 Share Posted February 17, 2017 Now I'm not very experienced in 30k yet, but doesn't the Command Rhino give you a +1 to reserve roles, and the Pale Hunter formation a +1 as well? As far as I know it doesn't get any better than 2+, so that sounds a bit redundant, or am I getting something wrong here? The Rest of the List looks interesting, a bit deathstary maybe, but I'm sure it can work! Link to comment Share on other sites More sharing options...
Purge the Daemon Posted February 17, 2017 Author Share Posted February 17, 2017 Now I'm not very experienced in 30k yet, but doesn't the Command Rhino give you a +1 to reserve roles, and the Pale Hunter formation a +1 as well? As far as I know it doesn't get any better than 2+, so that sounds a bit redundant, or am I getting something wrong here? The Rest of the List looks interesting, a bit deathstary maybe, but I'm sure it can work! Its either +1 or -1 it just seemed the easiest way to fit another HQ in. Which maybe can earn back its points somewhat. And maybe I block some energy reserves. Link to comment Share on other sites More sharing options...
K3nn3rs Posted February 17, 2017 Share Posted February 17, 2017 I've only got access to book 5 right now but I thinks it's +1 or -1 from YOUR reserve rolls. Limits its use slightly in your list. How about swapping it for a cheap centurion and dropping a vet? Link to comment Share on other sites More sharing options...
