Painting pale flesh
I tried it on a dwarf once, turned out pretty well for the amount of effort I put in, but it wasn't particularly pale (from memory it ended up looking fairly tanned), only doing a single thinned down coat might have made it paler, but I couldn't say for certain since I only tried it once.
I have used white with Reikland Fleshshade on top, gives a very pale skin tone as you'd expect. You need to be careful about application though if you want to keep it quite pale, focus the wash in the recesses for the most part. Rakarth Flesh is also a very good base for a lighter flesh colour, works very well so unless you're after a really pale look I'd go with Rakarth and Reikland :tu:
Here's a couple of examples of the Rakarth method:
Hidden Content
You could undercoat white or, if you like undercoating in black, spray it with Chaos Black (or your preferred spray / primer) and then basecoat with Rakarth Flesh. Here's a recipe for really pale - almost pallid - skin:
Rakarth Flesh basecoat
Reikland Fleshshade / Thinner (2:1) wash
Rakarth Flesh glaze layer
Rakarth Flesh / Pallid Wych Flesh (75/25) glaze layer
Rakarth Flesh / Pallid Wych Flesh (50/50) glaze highlight
Another recipe that I've used to great effect for pale skin:
Bugman's Glow undercoat
Cadian Fleshtone basecoat
Bugman's Glow wash
Cadian Fleshtone glaze layer
Cadian Fleshtone / Rakarth Flesh (75/25) glaze layer
Cadian Fleshtone / Rakarth Flesh (50/50) glaze highlight
But, for what you're trying to accomplish with so little area, I'd try this:
Reikland Fleshshade wash
Cadian Fleshtone / Rakarth Flesh (75/25) glaze highlight
I paint in glazes, obviously, so that's why I say "glaze layer" or "glaze highlight". Feel free to not glaze and omit that word from the above paint recipes. The steps will be the same.
On the last recipe, try diluting the Reikland Fleshshade with some thinner (Lahmian Medium or your preferred thinner) for a softer application because female skin looks better with less contrast. Probably a 2:1 mixture of Reikland Fleshshade to Lahmian Medium would suffice but it wouldn't be crazy to create a 1:1 mixture - you don't need deep shadows.
