sturguard Posted February 26, 2017 Share Posted February 26, 2017 Does anyone have any suggestions for making/buying combi weapons (melta/plas) for Tartaros termies? I refuse to spend $20- some dollars on a FW Tartaros special weapons pack which gives you 2 combi weapons. Are there any companies that make bits that would be suitable? Or does someone have a recipe for making some? Thanks! Link to comment https://bolterandchainsword.com/topic/331403-combi-weapons-for-tartaros-termies/ Share on other sites More sharing options...
VulkansDynasty Posted February 27, 2017 Share Posted February 27, 2017 the bolters that come with them are easily worked with, Just chop one in half, cut down the combi weapon option you want, and fit them together. You can make them look like the ones that come with the plastic Terminator Libbys and such with very little work. Link to comment https://bolterandchainsword.com/topic/331403-combi-weapons-for-tartaros-termies/#findComment-4667161 Share on other sites More sharing options...
Major_Gilbear Posted February 27, 2017 Share Posted February 27, 2017 The Combi-bolters come in two halves. Simply leave one half off (or trim one half down before you assemble it), and glue in a suitably-trimmed plasma pistol, hand flamer, or inferno pistol into place. Alternatively, just buy the Tigrus-pattern Legion Combi-weapon set from FW which has five of each weapon for £15. They are over-under configuration rather than side-by-side, but they fit perfectly well and are sized correctly. Link to comment https://bolterandchainsword.com/topic/331403-combi-weapons-for-tartaros-termies/#findComment-4667247 Share on other sites More sharing options...
Mirbeau Posted March 1, 2017 Share Posted March 1, 2017 I just use 40k combis, plenty of forge worlds in the galaxy no? Stands to reason the tech would be more advanced looking too. If you are a stickler, could carefully cut off the hand from the plastic mark IV kit, the combi bolter from the termi's hand and stick the two together . (dry fit with blutack below) Link to comment https://bolterandchainsword.com/topic/331403-combi-weapons-for-tartaros-termies/#findComment-4669841 Share on other sites More sharing options...
Mango Polo Posted March 8, 2017 Share Posted March 8, 2017 Alternatively, just buy the Tigrus-pattern Legion Combi-weapon set from FW which has five of each weapon for £15. They are over-under configuration rather than side-by-side, but they fit perfectly well and are sized correctly. Really now? Huh. Huuuuuuh. Maybe I ought to check before I throw myself into something else. Link to comment https://bolterandchainsword.com/topic/331403-combi-weapons-for-tartaros-termies/#findComment-4677590 Share on other sites More sharing options...
Svartmetall Posted March 8, 2017 Share Posted March 8, 2017 For Chaos Terminators, I like to use one half of the twin-linked/combi bolter on the Chaos vehicle accessories sprue, then improv the other half. For Snivelling Loyalist Weaklings...probably the same, just tidier. Link to comment https://bolterandchainsword.com/topic/331403-combi-weapons-for-tartaros-termies/#findComment-4677599 Share on other sites More sharing options...
shandwen Posted March 8, 2017 Share Posted March 8, 2017 I used half of the combibolter and then most of a plasma/melta pistol to make mine. They turned out rather well. Link to comment https://bolterandchainsword.com/topic/331403-combi-weapons-for-tartaros-termies/#findComment-4677655 Share on other sites More sharing options...
