Azazyll Posted February 27, 2017 Share Posted February 27, 2017 Does anyone here have good suggestions or tutorials for making one's own shields? Especially boarding shields? I'm a novice with plasticard, and the idea of trying to bend it to have the right curved shape is intimidating. Link to comment https://bolterandchainsword.com/topic/331449-tutorial-for-stormboardingcombat-shields/ Share on other sites More sharing options...
micahwc Posted April 5, 2017 Share Posted April 5, 2017 I think the easiest way would be to find a length of rod with the radius you want for your shield, coat it with a release agent, and then put a flattened sheet of green stuff over it. Wait for it to dry, pull it off, and shape it as you want to. Link to comment https://bolterandchainsword.com/topic/331449-tutorial-for-stormboardingcombat-shields/#findComment-4704374 Share on other sites More sharing options...
Major_Gilbear Posted April 5, 2017 Share Posted April 5, 2017 Cut the shape you want from thin plasticard. Dip it in hot water (not boiling, but still hot). Fish it out and wrap it around something that's a sightly smaller diameter than you want. Use elastic bands to keep it tight. Return it to the hot water for a bit. If you take two of these, and glue them together with some superglue (or even better, a little solvent weld), they form a sort of laminate that's the curvature you want. An alternative is to get two or three thin pieces of plastic, apply some plastic cement, and then elastic-band them tightly to your mould. When the glue is cured, they will be laminated to the curve you want. Suitable moulds are 40-60mm diameter pipe, which I'm sure you can buy a small piece of cheaply in a hardware store. Alternatively, you may have a small jar (like a spice jar) which is the right diameter. Whilst I do use both techniques, I generally prefer the hot water version for thinner items, even though it is more fiddly. The lamination is also a convenient way to achieve that layered look that many of the SM shields have. Edit: Of course, you can just make flat boarding shields! These are even simpler (because they don't need bending), and you can still overlay different pieces to get the desired look and thickness. :) Link to comment https://bolterandchainsword.com/topic/331449-tutorial-for-stormboardingcombat-shields/#findComment-4704754 Share on other sites More sharing options...
Hrolf the Cunning Posted April 8, 2017 Share Posted April 8, 2017 Gilbear with fantastic advice once again, the only thing i could think to add would be possibly exploring some of the molding options so you can duplicate your custom shields with a high degree of consistency, instant mold is probably a pretty easy to use option if you want to head down this path. Link to comment https://bolterandchainsword.com/topic/331449-tutorial-for-stormboardingcombat-shields/#findComment-4707094 Share on other sites More sharing options...
Brother-Chaplain Kage Posted April 9, 2017 Share Posted April 9, 2017 I made a custom terminator-sized breacher shield for a praetor out of sheet plastic. http://i.imgur.com/bEpJkAU.png I tried heating it in hot water and using a heat gun it, but it didn't do much. What I ended up doing was taking the handle of one of my tools and carefully bending the plastic sheet around the handle - start on one side of the shield, bend a little, shift the shield a millimeter or two, bend again, repeat. I had to do that 3-4 times all the way across to get the amount of curve I was looking for, but also being cautious so as not to bend it too much and put a big crease in it. A little time consuming, but worth not destroying the shield. Trim was added with strip plastic and plastic rivets. http://i.imgur.com/AG4U0c8.png Link to comment https://bolterandchainsword.com/topic/331449-tutorial-for-stormboardingcombat-shields/#findComment-4707264 Share on other sites More sharing options...
Tyberos the Red Wake Posted April 9, 2017 Share Posted April 9, 2017 Brother Chaplain Kage be like Link to comment https://bolterandchainsword.com/topic/331449-tutorial-for-stormboardingcombat-shields/#findComment-4707697 Share on other sites More sharing options...
Brother-Chaplain Kage Posted April 9, 2017 Share Posted April 9, 2017 I guess the explanation wasn't thorough enough? Here's the only decent sized shot of the shield I have between those two pics. http://i.imgur.com/buyCPYY.png My original idea was to sculpt half of the Crimson Sons icon on it but it didn't work out and you can see where I used some thick plastic strip to do the trim and greenstuff for the reinforcement around the gun port. Link to comment https://bolterandchainsword.com/topic/331449-tutorial-for-stormboardingcombat-shields/#findComment-4707742 Share on other sites More sharing options...
