3k iron warriors
Hey all got another game this week against the dreaded deathguard.
Never played them but excited for the game. My opponent is bringing mortarion and im sure an assortment of jacked up terminators with man reapers. Should be fun. I not bringing perturabo.
Let me know what you think of the list.
ROW: Iron Fire
Hq:
Preator 165 pts (with support squad)
Paragon blade, combi plasma, artificer, melta bombs, iron halo.
Siegebreaker 125 pt (with tyrants, confer tank hunter)
Artificer, refractor field, pfist
Elites:
Quad mortar 140 pts
2 x mortar w/ shatter shell (no phos bec death guard get fnp from poison)
Quad mortar 140 pts
2 x mortar w/ shatter shells
Troop:
Tactical squad 220 pts
9 x marines 1 x sgt
Bolters nuncio
Sgt w/ artificer and pfist
Rhino with dozer and multimelta
9 x marines 1 x sgt
Bolters nuncio
Tactical support squad 334 pts
6 x marines 1 x sgt
Plasma guns extra ccw
Fast attack:
Lightning strike fighter 230 pts
Battle servitor control, ground tracking auguries.
2 x kraken missiles
Heavy support:
Artillery squadron 310 pts
2 x medusas
Vindicator squadron 300 pts
2 x lazer vindicatorz
Armored ceramite
Tyrant siege termies 405 pts
6 x tyrant 1 x siege master
2 x chainfists
Low:
Typhon siege tank 455 pts
Armored ceramite, lascannons
3004 pts total.
Tactics. Use mobility and overwelming fire. Quad mortars target easy transports with shatter shells. medusas go for hard tgts. Lazer vidicators target tankz, elites and mortarion. Siege terminators go for vehicles. Typhon tgts death shroad and terminator squads. Rhinos remain flexible and use multi melta when able. Support squad ready to rapid fire terminatorz.
Thanks again.
https://bolterandchainsword.com/topic/331478-3k-iron-warriors/
I am building a lot similar list for IH so I would like to know how your list works. As I can't get extra HS slot I have instead put those points from Sicaran into Praevian and some automatas and don't have apothecarion as well.
Other than that the list is same.
Waiting for lazer vindis to arrive and after finishing them I have the list built.
Hammer of Olympia requires three compulsory troops choices so your list isn't legal as tactical support squads cannot be taken as compulsory troops.
However if you switch to the ironfire rite of war it will be. Then I would suggest taking the sicaran out (as you will be over on your heavy support) and replacing the sicaran venator with a whirlwind scorpius to maximise your barrages. Of course you will need to sprinkle nuncio voxes into your squads so you can hide your sources of barrages.
And bring an empty cup to fill with your opponents' tears.
You can nip a few points off by taking battlesmith from the praetor as it's no longer required but is fluffy.
If you're dead set on hammer of olympia then you will need to trim something to find the points for another tactical squad. Also what are you planning on running the praetor and apothecary with?I assume the plasma squad to mitigate gets hot deaths?
