themortalgod Posted March 4, 2017 Share Posted March 4, 2017 I'm working on a large terrain project that will use a LOT of Nuln Oil, I was wondering if anyone knows of any similar product on the market that is a bit more "bulk" than the small GW pots? Link to comment https://bolterandchainsword.com/topic/331601-bulk-alternative-to-nuln-oil/ Share on other sites More sharing options...
Stoic Raptor Posted March 4, 2017 Share Posted March 4, 2017 Long before Nuln Oil/Badab Black, we used to just use black ink. Mix it with glaze medium if you don't want it so strong. Link to comment https://bolterandchainsword.com/topic/331601-bulk-alternative-to-nuln-oil/#findComment-4672496 Share on other sites More sharing options...
brettfp Posted March 4, 2017 Share Posted March 4, 2017 On other larger projects I have just gotten generic black acrylic paint and heavily watered it down for use as a wash. Depending on what your doing with it it should work just fine :) Link to comment https://bolterandchainsword.com/topic/331601-bulk-alternative-to-nuln-oil/#findComment-4672647 Share on other sites More sharing options...
Major_Gilbear Posted March 4, 2017 Share Posted March 4, 2017 This is what you need! ;) Link to comment https://bolterandchainsword.com/topic/331601-bulk-alternative-to-nuln-oil/#findComment-4672791 Share on other sites More sharing options...
themortalgod Posted March 4, 2017 Author Share Posted March 4, 2017 Long before Nuln Oil/Badab Black, we used to just use black ink. Mix it with glaze medium if you don't want it so strong. I remember those days, I also remember ink drying a bit shinier than wash and never liking it. ;) On other larger projects I have just gotten generic black acrylic paint and heavily watered it down for use as a wash. Depending on what your doing with it it should work just fine Iv had a few people recommend that, but I've found that it doesn't seap into the cracks like GW washes do. It just puts a watered down layer of paint evenly over the surface? Link to comment https://bolterandchainsword.com/topic/331601-bulk-alternative-to-nuln-oil/#findComment-4672931 Share on other sites More sharing options...
Jarkaira Posted March 4, 2017 Share Posted March 4, 2017 Just add something that breaks the surface tension and it won't cover it evenly. Link to comment https://bolterandchainsword.com/topic/331601-bulk-alternative-to-nuln-oil/#findComment-4673019 Share on other sites More sharing options...
Stoic Raptor Posted March 4, 2017 Share Posted March 4, 2017 I remember those days, I also remember ink drying a bit shinier than wash and never liking it. Once it's topcoated with varnish, that doesn't matter much. Link to comment https://bolterandchainsword.com/topic/331601-bulk-alternative-to-nuln-oil/#findComment-4673139 Share on other sites More sharing options...
Kroupus Posted March 5, 2017 Share Posted March 5, 2017 Luke has a few money saving tips on his YouTube channel. Pretty decent to go through. https://youtu.be/5R48xhU_dy0 Link to comment https://bolterandchainsword.com/topic/331601-bulk-alternative-to-nuln-oil/#findComment-4673182 Share on other sites More sharing options...
Space Truckin Posted March 6, 2017 Share Posted March 6, 2017 What about Miniwax Stain as an bulk cheap alternative. Never used it for dipping myself but it appears to get similar results in a quick and dirty way. Link to comment https://bolterandchainsword.com/topic/331601-bulk-alternative-to-nuln-oil/#findComment-4674801 Share on other sites More sharing options...
Tyberos the Red Wake Posted March 6, 2017 Share Posted March 6, 2017 Vallejo sells larger bottles of high quality wash, but they are not huge bottles if that's the kind of bulk you needed, just much larger than GW. You can also thin wash 1:1 with thinner to make it last twice as long at the cost of not being as dark. Link to comment https://bolterandchainsword.com/topic/331601-bulk-alternative-to-nuln-oil/#findComment-4675262 Share on other sites More sharing options...
Lucumon Posted March 9, 2017 Share Posted March 9, 2017 I used to mix black paint and water (to thin out the black) with something called "Future Floor Wax" - It's an acrylic floor wax that breaks the surface tension. It does make things a bit shiney, but I overcoat all my models with Testors Dullcote now. Then again, I've started using Army Painter Dark Quickshade. Difference in results as well as a methodology here Link to comment https://bolterandchainsword.com/topic/331601-bulk-alternative-to-nuln-oil/#findComment-4678446 Share on other sites More sharing options...
