Help me decide my next project!
Hello fellow frater! With inferno finally firmly in my grasp I have come up with a short lit of projects I'd like to do (very very long term projects). But me being me, I simply cannot decide between the two main ones that draw my attention the most!
So I put the question to you brothers and sisters, which of the following two projects would you like to see me do the most! Cast your votes!!!!!
Idea one
This is inspired by the two pages in inferno detailing the forces present at prospero of both the defenders and the censure host. It basically involves doing a set points limit force to represent every seperate formation described (so for example a force for each 1k sons fellowship, wolf great company etc.). While having set points appeal to me, the unfortunate fact is that the points limit would have to be quite high to be able to do a force of just a single Ordo sinister Titan, which in turn would bump the points of every other force up quite high (my ocd unfortunately demands that each force must be the same points).
Idea two
This idea involves me taking the idea of the majority of the fourth fellowship not being present on prospero and expanding upon an Isolated circle from said fellowship who didn't receive the order to assemble at prospero who are set upon by a band of world eaters.
It would involve modelling the entirety of the forces present, which are most likely to include
1. Full circle of the 1k sons (in my mind around 300ish marines with support, including order of ruin and jackal support)
2. Cybernetica cohort from
Zhao-arkhad (unsure of numbers from this as I'm not too familiar with mechanicum fluff)
3. Legio Xestbiax maniple (1 reaver and 2 war hounds with some skitarii support)
4. Two assault companies of world eaters (in my mind they sit at around 200 marines each)
5. Imperial militia reserve batallion (I'd say this would sit at say 4 infantry companies at around 100 men each with some armoured support)
6. A knight household detachment (unsure on exact numbers but I'm thinking around 10-15 Knights)
Suffice it to say whichever option I end up doing it shall be documented here! But before that can occur, help me my fellow frater! You're my only hope!
https://bolterandchainsword.com/topic/331971-help-me-decide-my-next-project/
