Custodes Instructions
Charlo
Okay so I'm building my Custodes at the moment and have run into a bit of a predicament - obviously the kit gives you enough of everything to make 5 spear guys or 5 shield guys etc
....But the instructions (at least with Prospero) leave out how to make the last spear guy, only show a Vexilla carrier. I think I eventually managed to use the correct arms (though, one is rather far back) - but I'm going in blind here!
Does the new box outline all of the options like the Skitarii one for example? Could anyone share it?
https://bolterandchainsword.com/topic/332506-custodes-instructions/
The instructions I got with one of the bundles off FW and the instructions in the Talons box are the same as those in BoP as far as I can tell, unfortunately. Try to use the arms closest to the spear, with similar numbers, would be my advice.
I'll check again when I get home though.
Aye, that is what I did in the end!
It's annoying because the arms for the sword/ shield are usually in the same string of numbers as the spear arms...
