Command Squads: Bikes or Jetbikes?
Sorry if this has already been brought up but what are your thoughts on bikes vs. Jetbikes for command squads? For a max size command squad, it costs 100 more points for jetbikes over bikes. Is that 100 points worth it? I used to think it was because of the 2+ armor and heavy bolters but now that command squads have 2+ armor base I'm not sure if it's worth it anymore. The one case where I can maybe see it is Dark Angels so the jetbikes have acid shells, but even then that's an extra 25 points
It's a shame because I really like the theme of a jetbike command squad but 100 points is a bit much for me to ignore for personal taste.
Thoughts?
https://bolterandchainsword.com/topic/332528-command-squads-bikes-or-jetbikes/
Actually it's a 50pt difference, Command squads get a 10pt discount.
Also bear in mind that heavy bolter is worth 5pts over a TL bolter, while making them much more effective in range and the extra thrust move con be extremely useful for good positioning
Regular Bikes. The squad will already be a points sink and Dark Angels are the only ones who benefit enough from getting heavy bolters (but they probably still shouldn't take them as a command squad is often an assault ellement and shooting upgrades run the cost too high.)
That beinv said, 30k is about having a fluffy, cool looking, personalized army. Do what you want.
