3000 pts of Iron Hands, The Head of the Gorgon
Rite of War: Head of the Gorgon
HQ
Iron Father Autek Mor- 225 pts
Spearhead-Centurion Casterman Orth- 80 pts
Legion Praevian- 135 pts
                Cataphracti Armor
                Cyber Familiar
                Power axe
Troops
Legion Tactical: 190 pts
15 x tacticals
                Artificer armor
                Melta bombs
15 x tacticals
                Artificer armor
                Melta bombs
Legion Tactical Support Squad: 195 pts
5 x Tacticals
                Melta guns
                Combi-melta
                Rhino
Legion Tactical Support Squad: 460 pts (190 pts for tacticals, 270 for proteus)
6 x Tacticals
                Plasma guns
                Combi-plasma (sgt)
                Land Raider Proteus (Exploratory Auger Web, twin-linked las sponson)
Elite
Apothecary Detachment: 90 pts
                2 Apothecary
Heavy Support
Predator squadron: 320 pts
3 x predator
                Predator cannon
                Heavy Bolter sponsons
                Squadron command tank
Vindicator squadron: 360
3x vindiactor
Castellax- 280 (As elite)
                2x castellax
                Darkfire Cannons
                Enhanced Targeting array
Vorax- 255 (as elite)
                3x vorax
                3x irad cleanser
                Bio corrosive ammunition
Arlatax- 220 (as elite)
                Paragon of Metal
                Power Scourge
Notes-
Autek Mor is with the plasma support tacticals in the land raider proteus with casterman orth. He will grant preferred enemy to his plasma tacticals and to the Legion Praevian.
The legion praevian is going to be outflanking with the Vorax. He will be targetted by autek mor's preferred enemy (infantry), granting it to the vorax. This unit will either scout forward or outflank depending on the army.
Both the dakka preds and the vindicators will be outflanking.
The apothecarries will be with both of the tactical blobs who will be sitting in my deployment and enjoying being unmovable, stubborn, bricks.
There are a few ways this army can be tweeked, for example, paragon of metal on the arlatax can be removed to give the vindicators squadron commander. I also have a few slots to play with, currently I am using all 4 elite slots but I can shift one of the bot units to heavy support due to cortex controller and use the elite for something else.
A few pointers:
-The praevian takes the automata  as part of his HQ slot and is par of the unit, so you don't put them in your elites. He doesn't join them ever.
-He can give the unit he is with prefered enemy by tagging a unit with his bolter. I would use the WL trait on someone else.
-Autek Mor cannot joint the plasma support squad, the exploratory sensor web reduces transport capacity.
-Melta support squads will be very disappointing with the current prevalence of armoured ceramite, unless your group is very heavy on dreads and rhinos.
-Augury scanners are great on apothecaries
-try and tweak to upgrade the dakka pred sponsons to lascannons for some more robust anti armour.
-dozer blades are a must on aggressive tank play, and you should think about using pintle multi-melta to enhance your firepower.
I believe autek mor can still join the support squad as the proteus + auger has a transport capacity of 8.
You are correct on the praevian, he grants them PE depending on what he shoots at, which I forgot.
I think that replacing the meltas with volkite would probably work out ok. Better PE target anyway. The question is whether chargers + outflanking rhino or calivers and camp in the back.
I'd drop the melta squad to give the preds plasma executioners, then give the vidicators laser destroyers with command tank.
That's just my personal preference though. The destroyers with tank hunter are brutal, and the plasma covers the anti infantry the demolisher cannons would have covered.
