Polux's Warlord Trait...
No, that's not how it works. It simply grants one infantry unit the deep strike ability, which means that one unit will be in normal deep strike reserves rolling to arrive on turn two like any other unit in standard reserves. Doesn't really help much in a drop pod oriented list, the ability is more useful in a standard list where you have one unit you'd like to deep strike.
he has the master tactician WT which states: "after both sides are deployed but before which side gets the first turn is determined, the Warlord's side may redeploy one of their units within the limitations of the mission being played. This may place a unit that has been deployed normally into reserve, or bring a unit out of reserve."
Since this is a redeploy move and pods force you to deepstrike them in, you cant use this to get them on the board pre-T1, same with flyers.
And if you could redeploy them, it would have to be in your deployment zone like any other units in your army.
