Problems with Wild Rider red
Hi to all!
Maybe you guys can help me. My Marines have their shoulderpads in a bright redorange. Because Blazing Orange is no longer available I switched to Wild Rider Red. Problem is the paint seems to dry while painting. I always get brushstrokes and little "crumbs?" (if you can call it like that). Thinning down the paint doesn´t help and the brush is new.
Is this a common problem?
Did I missed something in Duncans videos? XD
https://bolterandchainsword.com/topic/332578-problems-with-wild-rider-red/
Actually, you might want to try stirring some Lahmian Medium into it.  Water's not going to do anything that thinning it on your palette won't, so if it's crumbly when you thin it, it'll still be crumbly if you add water to the jar.
Lahmian Medium is basically the fluid into which pigment is suspended.  From what you describe, the pigment doesn't have enough of that "carrier" any more, this might solve it.  Otherwise, you've got a bad pot.
