Mercay Posted April 14, 2017 Share Posted April 14, 2017 Does anyone know if the skyshield landing pad is tall enough to fit some munitorum containers beneath? I might just be bad at google but I can't seem to find any dimensions on the containers. The skyshield should be around 3" tall if I'm not mistaken. I have my doubts that it would fit but would like to get it confirmed if anyone knows! Link to comment https://bolterandchainsword.com/topic/332975-munitorum-containers-height/ Share on other sites More sharing options...
Chaplain Raeven Posted April 15, 2017 Share Posted April 15, 2017 I'll measure them up when I get home, but I can say already that they are quite tall. A marine with banner has almost the same height. Link to comment https://bolterandchainsword.com/topic/332975-munitorum-containers-height/#findComment-4711816 Share on other sites More sharing options...
DistroyA Posted April 15, 2017 Share Posted April 15, 2017 Without the storm bolters, the containers measure at roughly 60mm in height. Add another 15mm if you're attaching the storm bolters. Link to comment https://bolterandchainsword.com/topic/332975-munitorum-containers-height/#findComment-4711834 Share on other sites More sharing options...
Chaplain Raeven Posted April 15, 2017 Share Posted April 15, 2017 Which would translate in +/- 2,5". Link to comment https://bolterandchainsword.com/topic/332975-munitorum-containers-height/#findComment-4711845 Share on other sites More sharing options...
Mercay Posted April 15, 2017 Author Share Posted April 15, 2017 Hmm alright, seems like it might actually fit then, thanks guys! Link to comment https://bolterandchainsword.com/topic/332975-munitorum-containers-height/#findComment-4711872 Share on other sites More sharing options...
Canadian_F_H Posted April 15, 2017 Share Posted April 15, 2017 What are their dims overall? I intend to build some standins. Don't want the gw ones... but I want the size to be about right to avoid "MFA" accusations. Link to comment https://bolterandchainsword.com/topic/332975-munitorum-containers-height/#findComment-4711895 Share on other sites More sharing options...
MagicHat Posted April 15, 2017 Share Posted April 15, 2017 Length: 11.8 Cm or 4 and a bit more then a half ". Width: 6 Cm or 2 and slightly less then a half ". Height: 6 Cm. Could have sworn that they would be taller then their width, but there you go. SB not included, because I refuse to have containers be better armed then the standard gear of a SM transport. Link to comment https://bolterandchainsword.com/topic/332975-munitorum-containers-height/#findComment-4712053 Share on other sites More sharing options...
Mercay Posted April 16, 2017 Author Share Posted April 16, 2017 Length: 11.8 Cm or 4 and a bit more then a half ". Width: 6 Cm or 2 and slightly less then a half ". Height: 6 Cm. Could have sworn that they would be taller then their width, but there you go. SB not included, because I refuse to have containers be better armed then the standard gear of a SM transport. Thank you very much! Link to comment https://bolterandchainsword.com/topic/332975-munitorum-containers-height/#findComment-4712391 Share on other sites More sharing options...
