OrangeBob Posted April 19, 2017 Share Posted April 19, 2017 Hello, I'm wondering if there is anything I need to know about priming (with a spray can, hopefully) some combat shields that I bought off of Shapeways? I've never worked with this stuff and the last thing I want to do is ruin my purchase. Any help would be appreciated, even if it's "proceed as normal, business as usual." Thanks, Orangebob Link to comment https://bolterandchainsword.com/topic/333069-priming-3d-printed-material/ Share on other sites More sharing options...
Paradigm Posted April 19, 2017 Share Posted April 19, 2017 It should prime like any other plastic. Assuming you didn't order a print in an exotic material. The plastics aren't styrene, but paint won't know the difference. You may notice your plastic glue isn't as effective, though. Link to comment https://bolterandchainsword.com/topic/333069-priming-3d-printed-material/#findComment-4714268 Share on other sites More sharing options...
apologist Posted April 19, 2017 Share Posted April 19, 2017 I've used both detail and ultra detail from Shapeways, and both have been ready to paint. I primed mine as usual – no washing necessary – and haven't had any problems yet. Link to comment https://bolterandchainsword.com/topic/333069-priming-3d-printed-material/#findComment-4714285 Share on other sites More sharing options...
OrangeBob Posted April 19, 2017 Author Share Posted April 19, 2017 Hi Guys, Thanks for sharing. I kind of figured, but was still a little nervous. Link to comment https://bolterandchainsword.com/topic/333069-priming-3d-printed-material/#findComment-4714573 Share on other sites More sharing options...
Subtle Discord Posted April 19, 2017 Share Posted April 19, 2017 The Sapeways Polyjet process will use a wax as a support structure as it prints the part. Shapways will give it a heat treatment to melt the wax and and a wash to remove the residue as part of their process. Simple objects will clean easily and be free of all residue, but more complex objects/details may have a bit remaining. You should be fine without it most of the time, but if you want to be really safe just give the parts a wash with some isopropyl alcohol and a light scrub with a old toothbrush. Link to comment https://bolterandchainsword.com/topic/333069-priming-3d-printed-material/#findComment-4714620 Share on other sites More sharing options...
OrangeBob Posted April 20, 2017 Author Share Posted April 20, 2017 Thanks, Subtle. Couldn't hurt to be extra careful I suppose. Link to comment https://bolterandchainsword.com/topic/333069-priming-3d-printed-material/#findComment-4714882 Share on other sites More sharing options...
