Inferno's campaign missions
I'm looking through the missions and in primary objectives says: The player who earns the most victory points is the winner. But doesn't say what gives you victory points. Do you have to count then all the secondary and additional victory points?
Also the first mission gives the TS player a victory point for each model killed bya any of his psykers, If you take Magnus let's say that it would be a bit hard to lose...
Also, do you pick whatever mission you fancy since there are no mission tables?
https://bolterandchainsword.com/topic/333327-infernos-campaign-missions/
The Inferno missions are poorly written and kind of a joke (this coming from a Thousand Sons player)
There is Legitimately a mission that says balance sides, 2000/2000, 3000/3000 ect..
Then give the TS side a Titan in addition to their points.
There is no correct answer to your question so just houserule it however you want with whoever you are running the campaign with.
