Ovidius Incertus Posted April 30, 2017 Share Posted April 30, 2017 I am considering working a Malifaux Rasputina mini as an Inquisitor or similar and maybe pilfering the wings from a Kaeris mini. I've done some searching and few of the size comparisons I've found are very detailed and most seemed to be comparing old metal versions of the models to squatting marines, if that. Anyone able to compare the new Malifaux plastics to more recent GW minis? FWIW, I do biggerize most of my Marines, so if she's Guard sized, it's all good. Link to comment https://bolterandchainsword.com/topic/333333-malifaux-figures-size-comparison/ Share on other sites More sharing options...
Kilofix Posted May 1, 2017 Share Posted May 1, 2017 Slightly thinner than Guard. But don't have a handy photo. Link to comment https://bolterandchainsword.com/topic/333333-malifaux-figures-size-comparison/#findComment-4726278 Share on other sites More sharing options...
sockwithaticket Posted May 1, 2017 Share Posted May 1, 2017 Probably taller. I've got Sonia Criid on my desk and shes about a head taller than a marine (admittedly she's in heels), but she's also thinner and better proportioned than any GW human figure. Will definitely stand out.Malifaux plastics and metals in my experience are generall pretty similar, metals a little bit smaller. Link to comment https://bolterandchainsword.com/topic/333333-malifaux-figures-size-comparison/#findComment-4726430 Share on other sites More sharing options...
Major_Gilbear Posted May 1, 2017 Share Posted May 1, 2017 Much thinner and a bit taller. You'll notice the proportional differences much more than the height differences. You would be better off with the older Dark Age Apocalypse or Wild West Exodus figs if you're after more exotic figs to use as Inquisitors and the like. In a pinch, the older (1st edition metal) Malifaux figures are a better bet I'd say, and even some Warmachine ones - sorsha Kratikoff is a good/popular figure for this. Link to comment https://bolterandchainsword.com/topic/333333-malifaux-figures-size-comparison/#findComment-4726711 Share on other sites More sharing options...
micahwc Posted May 2, 2017 Share Posted May 2, 2017 I don't have them anymore but I use to paint a lot of Malifaux. I'd guess the old metal minis are about the size of a guardsman + or -, but they are a lot thinner since they are not heroic scale. Raspy doesn't have any weapons which will help a bit, since the Malifaux weapons are a lot thinner and smaller proportionally than the GW ones. I don't think she would look too out of place; I imagine the varied worlds in the imperium have varied living conditions, which produce varied sizes of people between the Rattling's and Ogryns. Some thinner, some taller, some thicker, some shorter, etc. For a similar look you could also go with Commander Sorcha ( not sure on spelling) from Warmachine. I think Privateer Press uses heroic scale, so she would be about the right size and the right proportions. She has a very similar aesthetic to Rasputina; I,e, Russian militaristic chick in a Russian winter hat. Link to comment https://bolterandchainsword.com/topic/333333-malifaux-figures-size-comparison/#findComment-4727944 Share on other sites More sharing options...
CommodusXIII Posted May 3, 2017 Share Posted May 3, 2017 Much thinner and a bit taller. You'll notice the proportional differences much more than the height differences. You would be better off with the older Dark Age Apocalypse or Wild West Exodus figs if you're after more exotic figs to use as Inquisitors and the like. In a pinch, the older (1st edition metal) Malifaux figures are a better bet I'd say, and even some Warmachine ones - sorsha Kratikoff is a good/popular figure for this. Wild West Exodus miniatures are also slightly out of scale (35 mm versus 28 mm). Link to comment https://bolterandchainsword.com/topic/333333-malifaux-figures-size-comparison/#findComment-4729385 Share on other sites More sharing options...
