Death Guard Intractable rule
I've been out of the loop for a while - call me a "casual hobbyist" - so I apologize if this question seems silly or treads on old ground.
The Death Guard's special rule "Intractable" states, "When making Sweeping Advance rolls, models with this special rule reduce their score by -1."
Does this mean DG units are more likely to be wiped out by an opponent winning a close combat? Assuming both units' I values are equal, DG units are more likely to be killed by the Sweeping Advance, yes?
Turn the tables. A DG unit wins a round of close combat and forces an opponent unit to Fall Back so they roll off for Sweeping Advance. Again, assuming equal I values, does this mean DG units are more likely to let the other chaps slink away and live?
https://bolterandchainsword.com/topic/333444-death-guard-intractable-rule/
I've always interpreted it as a -1 for both pursuing and fleeing. The rulebook says that the 'victors' make a Sweeping Advance, but when a Sweeping Advance is performed, both units roll - so I took it as the rule says 'making Sweeping Advance rolls,' that it is for both.
Also, it wouldn't make much sense to me that they were stubborn when it came to pursuing but not to running away.
