1k Sons 2000 point list
Hi wanted to make a 1k sons list trying not to use Magnus/Amon or Ahriman.
Wanted to use the blades because I love the models! Going to go mainly biomancy for powers for stat and combat buffs. Praetor+Libby with the blades in spartan.
Let me know what you think.
Thinking of extending the list to 2500 with some points tweaked to allow a fellblade as I love that model too.
Thanks
_Thousand Sons 30k_
_Legiones Astartes_
**Praetor**: Psyker (Mastery Level 3); Paragon blade; Arcane Litanies
**Osiron Dreadnought Talon**
- **Osiron Dreadnought**: Kheres pattern assault cannon
**Librarian**: Mastery Level 2 _
**5 Tactical Support Marines**: Tactical Support Sergeant; 4 Tactical Support Marines; rotor cannons (Asphyx shells)
**10 Tactical Space Marines**: Tactical Sergeant; 9 Tactical Space Marines
- **Rhino**
- **Rhino**
**Contemptor Mortis Dreadnought**: 2 Kheres pattern assault cannons
**10 Khenetai Blades**: Khenetai Blademaster; 9 Khenetai Blades
**Sicaran Venator Tank Destroyer**
**Spartan Assault Tank**
_1,995 points_
https://bolterandchainsword.com/topic/333450-1k-sons-2000-point-list/
Here's a different take that I'm playing with
Please let me know what you think
_Thousand Sons Terminators_
_Legiones Astartes_
**Praetor in Terminator armour**: Psyker (Mastery Level 3); Paragon blade; Arcane Litanies
- **3 Chosen Terminators**: Terminator Standard Bearer; 2 Chosen Terminators
- **Land Raider Phobos**
**Librarian in Terminator armour**: Mastery Level 2
**10 Veteran Space Marines**: Veteran Sergeant; 9 Veteran Space Marines; Brotherhood of Psykers (Mastery Level 1)
- **Rhino**
**5 Sekhmet Terminators**: Sekhmet Inceptor; 4 Sekhmet Terminators
**5 Heavy Support Marines**: Heavy Support Sergeant; 4 Heavy Support Marines; missile launchers; flakk missiles
**Fellblade Super-heavy Tank**: Space Marine Legion Crew; armoured ceramite
_2,515 points_
I think both lists feel like they lack focus somehow.
The characters as well as the Tacs and / or Vet Tacs are sorta under-equipped.
A unit of 5 Tac Supports will be dead turn one and absolutely doesn't justify the points for Asphyx. Either go big or go home with this unit.
I see your point, here's a tweaked list. My idea behind is terminators teleport in because of the right of war. Rest of army is shooting based meant to sit back and let rip. I've taken a fortification but haven't checked if I can with this right of war as the books at work. Let be know what you think. Thanks
_Legiones Astartes_
Rite of War (The Guard of the Crimson King);
**Librarian in Terminator armour**: Mastery Level 2; Arcane Litanies
**10 Tactical Support Marines**: Tactical Support Sergeant; 9 Tactical Support Marines; rotor cannons (Asphyx shells)
**5 Heavy Support Marines**: Heavy Support Sergeant (augury scanner); 4 Heavy Support Marines; missile launchers; flakk missiles
**5 Heavy Support Marines**: Heavy Support Sergeant (augury scanner); 4 Heavy Support Marines; lascannons
_Allied Fortifications (Age of Darkness)_
**Aegis Defence Line**: Comms Relay
_2,500 points_
The list lacks punch. What are going to do if you face multiple AV 14? Fellblade is cool, but kinda lackluster imo and doesn't do that anti-tank job very well either.
Drop heavy support teams and maybe tactical support too and take some serious AT with the points. Mortis should be changed to podded dual fist Contemptor, dropping Leviathans are also good.
You could also change the Fellblade to a Falchion. Gives you powerful anti-tank firepower and D is overally good.
Also a little reminder, its Rite of War not Right of War. Nothing personal, and probably just a mistake, but an annoying one biggrin.png
its got everything good from Ksons rules in it but still lacking a tiny bit. 2x 5 man heavy support squads will get deleted in no time. better that you make 1x10.
Fellblade is a great looking tank but doesnt scream thousand sons to me i would be more likely to go for glaive, falchion, cerebrus. nothing more space wizardy than laser beams.
Im unsure as well if you can take a fortification im not near my book but im 99% sure its no allies and no fort.
easy.... Apple auto correct will quite often change "rite" to "right" depending on the context.
Here's another idea for a possible army
Thousand Sons Shooting
Legiones Astartes
Ahzek Ahriman
• 4 Space Marine Chosen: Standard Bearer; 3 Space Marine Chosen
Librarian: Cult Arcana (Pavoni); Mastery Level 2; Arcane Litanies
10 Tactical Support Marines: Tactical Support Sergeant; Cult Arcana (Corvidae); 9 Tactical Support Marines; rotor cannons (Asphyx shells)
10 Tactical Space Marines: Tactical Sergeant; Cult Arcana (Corvidae); 9 Tactical Space Marines
• Rhino
• Rhino
Contemptor Mortis Dreadnought: 2 Kheres pattern assault cannons
9 Khenetai Blades: Khenetai Blademaster; Cult Arcana (Pavoni); 8 Khenetai Blades
• Land Raider Phobos
Achilles-Alpha Land Raider
2,000 points
