suxdavide Posted May 18, 2017 Share Posted May 18, 2017 Hello I've decided to join the Raven Guard's legion even if I started with AL, some problems made me change sides but I kinda liked the way AL played so I tried to match it in RG.Any suggestion? :) 1) I yet have to buy the batteries so those are just filling points atm2) I still have 65 points left but I don't know how to place them3) I'd like to have something using droppod but atm I don't have any and I'd stick with rhynos and the spartan (quite mandatory since I spent quite a few $ here)4) I don't own a Storm Eagle, I know it would greatly fit better but that's the situation5) This won't be the final list but a starting point from the things I actually own, which are in the img I'll be attaching at the end of the post, so if you can work on those pieces I'd much appreciate ^^6) I may be an AL infiltrated in RG but who cares, you know nothing and I'm no Alpharius :P++ The Age of Darkness (Legiones Astartes: Age of Darkness Army List) [2935pts] ++ + HQ + Legion Centurion [145pts]: Artificer Armour, Jump Pack, Melta Bombs, Power Weapon, Refractor Field. Consul: Chaplain Legion Praetor [165pts]: Cataphractii Terminator Armour with Combi-bolter and Power Weapon, Pair of Raven's Talons + Elites + Apothecarion Detachment [170pts]. Legion Apothecary. . Additional Wargear: Artificer Armour, Chainsword/Combat Blade. Legion Apothecary. . Additional Wargear: Chainsword/Combat Blade, Jump Pack. Legion Apothecary. . Additional Wargear: Artificer Armour, Chainsword/Combat Blade Contemptor-Mortis Dreadnought [180pts]: Kheres Pattern Assault Cannons x 2 Legion Rapier Weapons Battery [150pts]. Legion Rapier Weapons Battery: Graviton Cannon. Legion Rapier Weapons Battery: Graviton Cannon Mor Deythan Strike Squad [205pts]: 5x Combi-weapon, Legion Rhino Armoured Carrier, 4x Mor Deythan + Troops + Legion Terminator Squad [540pts]: Cataphractii Terminator Armour with Combi-bolter and Power Weapon, 4x Legion Terminators, 2x Pair of Raven's Talons. Legion Spartan Assault Tank: Heavy Flamer, Quad Lascannon Sponsons, Twin-Linked Heavy Bolter Legion Veteran Tactical Squad [275pts]: 9x Legion Veteran Space Marines, Veteran Tactics: Resolve. Additional Wargear: Melta Bombs, 2x Meltagun. . Power Weapon: Power Axe. . Power Weapon: Power Axe. Legion Rhino Armoured Carrier. . Combi-weapon: Combi-weapon: Meltagun. Legion Veteran Sergeant: Bolt Pistol, Bolter, Chainsword/Combat Blade Legion Veteran Tactical Squad [210pts]: 9x Legion Veteran Space Marines, Veteran Tactics: Marksmen. Additional Wargear: 2x Missile Launcher and Suspensor Web. Legion Veteran Sergeant: Bolt Pistol, Bolter, Chainsword/Combat Blade Legion Veteran Tactical Squad [210pts]: 4x Legion Veteran Space Marines, Veteran Tactics: Resolve. Additional Wargear: 2x Plasma gun. Legion Rhino Armoured Carrier: Heavy Bolter. Legion Veteran Sergeant: Artificer Armour, Bolt Pistol, Bolter, Raven's Talons + Fast Attack + Dark Fury Assault Squad [180pts]: 4x Dark Fury. Chooser of the Slain: Melta Bombs + Heavy Support + Deredeo Pattern Dreadnought [220pts]: Aiolos Missile Launcher, Twin-linked Anvilius Pattern Autocannon Battery, Twin-Linked Heavy Bolter Legion Heavy Support Squad [285pts]: Autocannon, 9x Legion Space Marines + Legion + Legiones Astartes: XIX: Raven Guard, Loyalist Rite of War: Pride of the Legion + Force Organization + Force Organization. Battles in the Age of Darkness: Age of Darkness Primary Detachment ++ Total: [2935pts] ++ http://i.imgur.com/STMuix5.png Link to comment https://bolterandchainsword.com/topic/333730-3k-raven-guard-from-al/ Share on other sites More sharing options...
suxdavide Posted May 21, 2017 Author Share Posted May 21, 2017 up Link to comment https://bolterandchainsword.com/topic/333730-3k-raven-guard-from-al/#findComment-4749216 Share on other sites More sharing options...
Lord Asvaldir Posted May 27, 2017 Share Posted May 27, 2017 Two main weaknesses I see with this list. First one, generally you're not spending pts effectively because a unit of 10 marines is cheaper than 5 pts per model wise. You have 3 units of 5 where that's the case. I'd drop one of those units of 5 and increase the numbers of your other units to make them more effective. Same case with the terminators, a unit of 5 in a Spartan is a lot of pts but not terribly effective. Increasing their numbers by dropping something, maybe the rapiers would be effective. Second main weakness is your anti armor capabilities, specifically against really tough av14 vehicles. At 3k pts you can be facing super heavies like a fellblade. Most cost effective way of dealing with that would probably be taking a lightning with kraken missiles. If you need pts those autocannon marines aren't as useful so you can drop them. Link to comment https://bolterandchainsword.com/topic/333730-3k-raven-guard-from-al/#findComment-4756972 Share on other sites More sharing options...
suxdavide Posted May 29, 2017 Author Share Posted May 29, 2017 Thank you for your reply As for the two problems you showed:1) I know I'm not optimizing the list but those are the models I currently own, I was then looking at using them before jumping into buying more... The terminators you're right what would you change them with? Better deploy a blob inside the spartan? :) 2) The rapiers are in to fill points (and I don't own the models too). What would you add then? :)How would you change the list based on the two problematics? Link to comment https://bolterandchainsword.com/topic/333730-3k-raven-guard-from-al/#findComment-4759400 Share on other sites More sharing options...
suxdavide Posted September 25, 2017 Author Share Posted September 25, 2017 ++ The Age of Darkness (Legiones Astartes: Age of Darkness Army List) [2997pts] ++ + HQ + Centurion [140pts]: Bolt Pistol, Jump Pack, Pair of Raven's Talons, Power Armour. Consul: Chaplain Legion Praetor [145pts]: Artificer Armour, Chainsword or Combat Blade, Jump Pack, Thunder Hammer + Elites + Apothecarion Detachment [120pts]. Legion Apothecary: Chainsword/Combat Blade, Jump Pack. Legion Apothecary: Chainsword/Combat Blade, Jump Pack Contemptor-Mortis Dreadnought [180pts]: Kheres Pattern Assault Cannons x 2 Legion Veteran Tactical Squad [290pts]: Legion Drop Pod, Melta Bombs, Veteran Tactics: Resolve. Legion Veteran Sergeant: Bolt Pistol, Bolter, Chainsword/Combat Blade. Legion Veteran Space Marines: Bolt Pistol, Bolter. . Power Weapon: Power Axe. Legion Veteran Space Marines: Bolt Pistol, Chainsword or Combat Blade. . Combi-weapon: Combi-weapon: Meltagun. Legion Veteran Space Marines: Bolt Pistol, Bolter, Chainsword or Combat Blade. Legion Veteran Space Marines: Bolt Pistol, Bolter, Chainsword or Combat Blade. Legion Veteran Space Marines: Bolt Pistol, Bolter, Chainsword or Combat Blade. Legion Veteran Space Marines: Bolt Pistol, Bolter. . Power Weapon: Power Axe. Legion Veteran Space Marines: Bolt Pistol, Chainsword or Combat Blade. . Combi-weapon: Combi-weapon: Meltagun. Legion Veteran Space Marines W/ Special Weapon: Bolt Pistol, Chainsword or Combat Blade, Meltagun. Legion Veteran Space Marines W/ Special Weapon: Bolt Pistol, Chainsword or Combat Blade, Meltagun Mor Deythan Strike Squad [312pts]: 6x Combi-weapon, 2x Flamer, 7x Mor Deythan. Legion Rhino Armoured Carrier: Dozer Blade, Multi Melta + Troops + Legion Assault Squad [320pts]: 19x Legion Assault Space Marines. Legion Assault Sergeant: Single Lightning Claw Legion Reconnaissance Squad [100pts]: 4x Legion Space Marines, Power Armour Legion Tactical Squad [195pts]: 9x Legion Tactical Space Marines. Additional Wargear: Bolters. Legion Rhino Armoured Carrier: Dozer Blade, Multi Melta. Legion Tactical Sergeant: Lightning Claw Legion Tactical Squad [215pts]: 9x Legion Tactical Space Marines. Additional Wargear: Additional Chainswords/Combat Blades, Bolters. Legion Rhino Armoured Carrier: Dozer Blade, Multi Melta. Legion Tactical Sergeant: Chainsword/Combat Blade, Lightning Claw + Fast Attack + Dark Fury Assault Squad [325pts]: 9x Dark Fury + Heavy Support + Legion Heavy Support Squad [285pts]: Autocannon, 9x Legion Space Marines + Allegiance + Legion and Allegiance: XIX: Raven Guard, Loyalist Rite of War: Decapitation Strike + Lords of War + War Machine Detachment [370pts]: Questoris Knight Errant ++ Total: [2997pts] ++ Something like this? Link to comment https://bolterandchainsword.com/topic/333730-3k-raven-guard-from-al/#findComment-4894700 Share on other sites More sharing options...
