Cryptix Posted May 26, 2017 Share Posted May 26, 2017 I'm starting a beastmen Abhuman cult army for the HH based on Skaven and using Tzaangor weaponry and I was wondering if anyone knew a quick and easy tutorial for white fur and albino skin? If you knew any recipes for leather that would be great too. Link to comment https://bolterandchainsword.com/topic/333939-albino-fur/ Share on other sites More sharing options...
Master Commander Ajax Posted May 27, 2017 Share Posted May 27, 2017 Warhammer TV has this. I'd be more inclined to try colours with a hint of tan in them. A basecoat of Zandri Dust followed by a thin wash of Seraphim Sepia before dry brushing up through Zandri Dust, Screaming Skull and a finally a light drybrush of White Scar. Link to comment https://bolterandchainsword.com/topic/333939-albino-fur/#findComment-4756164 Share on other sites More sharing options...
Bryan Blaire Posted May 28, 2017 Share Posted May 28, 2017 Cryptix, if you are still looking for ideas: Here is an image of a slightly darker than albino, but pallid, attempt at flesh, and here is my paint scheme for it. I think if I had to change anything, I would use a more thin wash of Reikland Fleshshade, and then use some Guilliman Blue across the entire surface before going back in with the Rakarth Flesh, because human albino skin can have a light purple tone due to the veins and vessels running below it. Another interesting thing to watch may be with a very similar scheme to mine that comes up with a white toned skin. For the fur, I agree with Master Commader Ajax above, but I wouldn't go down to Zandri Dust, the darkest I'd probably start would be Ushtabi Bone, then Seraphim Sepia - but truthfully, I'd try starting painting a base of Rakarth Flesh, completely covering that with Screaming Skull, shading it all with Seraphim Sepia, then doing an overbrushing with Screaming Skull, and a final Drybrush with White Scar. This should give you a very pale white fur with just a hint of a blonde seeming under-layer to the fur. Link to comment https://bolterandchainsword.com/topic/333939-albino-fur/#findComment-4757538 Share on other sites More sharing options...
