After Badab. Mechanicus inq28 finished
binary
That is looking well, but you might want to do some GS into the connection on the barrels of the autocannons. Thinks look a little off at the moment, due to not lining up and how they were cut.
Really digging the extra detail added around the collar and such. Really helps add some definition.
  • 2 weeks later...
Thanks thousand eyes. Hadn't spotted that with the barrels, so I'll sort it!
I cannot even at the awesome in this thread. What the actual :censored: !
Can't wait to see a full army shot when you're... "Done" ;)
Haha Charlo, thanks mate....that'll be a while though!
WIP updates!
So thought I'd share some WIP shots as a bit of an update. I also documented the build process for the Deredeo's ammo belt as the forgeworld ones didn't fit with the pose
Firstly inspiration struck from the strangest place
The nib from a cheap pen is the right size for the shells the deredeo's autocannons
After stripping 100 pens (they were dirt cheap!) this is what I ended up with
Added a few thin strips of masking tape and ended up with these
Then attached them to the deredeo's cannons and hopper. I then coated the belt in super glue to retain its shape
This is where he is now as I've started applying the base coat
Devestator squad is also at the same stage
And the sergeant. I wanted a way to illustrate the squad's signum so resin cast the head of the auspex from the stern guard box, then mounted a green LED inside.
More to come!
Impressive.
Well I aim to please!
Love the ammo feed belts, great work. Insane idea but it looks really well.
Insane about covers it! I wanted something different from the stock forgeworld look and I think this looks just different enough.
Updates!
And after a few hours work today I think the Deredeo is finished.
I painted the details in a similar style to the cataphractii painted earlier, as I see the Deredeo as the dreadnought equivalent of cataphractii armour. Only thing missing is transfers as I'm designing a custom sheet and want to do the whole army in one go.
Presenting "Honoured Helaine" the Bastion of Mancora
And lit up
As usual, c&c welcome
Excellent work on the Dreadnought.
looking awesomemate!! motivates me to press on with my own Deredeo
Thanks for the encouragement guys!
Updates!
So I finished up the first devestator squad. Squad Gawair are the 9th squad of 4th company and are honoured, or some would say cursed, with the chapter's only Mars pattern Plasma Cannons. Known collectively as "The Brothers" and individually as "Almacet" "Durendai" "Auteclar" and "Curtana" they are said to be named after ancient mighty weapons from mythology.
Sergeant Gawair was promoted to squad leader following the fatal injury of his Veteran sergeant and mentor Helaine.
Helaine's wounds led him to be interred in a Deredeo Chassis so that he may still advise and guide his prodigy
Individual shots
Sergeant Gawair - yes the auspex screen lights up
And the rest of the squad
Finally some action shots with second tactical
This is impressive on so many levels, especially how you fit a LED into an auspex, those things are tiny!
There are no problems with heating when enclosing wires like this? Any resistances needed or just batteries and LEDs?
Thanks mate, thankfully there's no heating issues at all as the LEDs draw so little power when they're on. The blue, pink and green LEDs all run on the same amps so don't need resistors if I'm running any combination of them. The red and yellow do need a resistor if I'm running them with another colour, but not if they're the only one on the model.
Must admit, very impressed.
Love the bolter fire!
Thanks! The bolter fire is probably one of my favourite bits too, and gave me the inspiration for the next part of the project
Updates!
Spent a few hours today trialling my plan for the assault squad. While GW have given us a more dynamic pose with the assault marines, I wanted to incorporate the LEDs into the jump packs to make it look like they've either just taken off or are just landing.
Here's where I am so far. The exhausts are cast in resin like the helmet and where originally modelled as the fire effect for my heavy bolsters. They are only blue tac'd in place as I want to paint the figure before attaching it.
  • 2 weeks later...
Updates!
Spent yesterday finalising the first 5 members of the assault squad. Each has 2 blue LEDs mounted in the jump pack to represent the thruster and 1 in the helmet as usual. I wanted to do something different with the sergeant, so decided to see if I could fit an LED and firing effect into a tiny bolt pistol. Happy to say that it fits!
Also built 1st tactical's rhino. The headlights are cast resin, the interior has a red LED and the front plate is mounted using magnets
And lastly, Captain Uthor. Now this conversion involved what is British refer to as "squeaky bum time". Decided to make him stand out by combining the forgeworld Garro and the second limited edition web captain, and believe me, attacking both models with a dremmel was scary!
Amazing work as every, binary, I love following your progress in this log. :cool.:
You've beat me to it with the jump packs! :biggrin.: I was planning to do a similar thing with my Crimson Fists Inceptors, although I think I'll go with yellow rather than blue. The blue does look good though! Keep it up. :happy.:
  • 3 weeks later...
Anyone ever told you that you are clinically insane?!
Amazing stuff as always. Love the Garro captain and night shots!
You're not the first person to say that Charlo, and you won't be the last!
Wow, high praise indeed from the LED master. Bob you continue to inspire me to do more and more insane things with my projects.
Updates!
More work finished with the the fourth company.
The first combat squad of 7th Assault are finished. Have to say these were the toughest so far to build due to the limited space in the jump pack to fit the 2 LEDs without creating a short in the wiring
And to go along with Captain Uthor I also built the first of my Lieutenants.
Lieutenant Melehan was built using the forgeworld praetor's body and backpack, the second limited edition web captain's legs, sternguard arms and a "headhunter" pattern storm bolter. This was a sternguard bolter with an extra barrel added to give it and "under/over" look
Captain Uthor, as mentioned in a previous post is built using forgeworld's Nathanial Garro, using the cape and power fist from the limited edition second web captain, a 30k plasma pistol and a custodes shield
I also finished second tactical's rhino.
And finally some glamour shots
Assault squad Bedeven land and secure the entrance to the Hall of Correction, Tibannopolis, 922.M39
Captain Uthor and Lt. Melehan oversee the final assault of the Hall of Correction, Tibannopolis, 922.M39
Second tactical squad led by Sergeant Agravail secure the Spiral Courtyard, Tibannopolis, 922.M39
  • 4 weeks later...
I seriously hope you win best in show to any even you go to with this force, if not, then the whom ever was grading armies needs to get their head checked by a proctologist....
Thanks for the compliment. Although I see this as more of a modelling project, they get their first outing at Armies on Parade this year!
This is really well done and those night pictures look fantastic!
I try :whistling: The scenery is actually the armies on parade board that I built 2 years ago, and I figured that ding them as night shots would look a lot more dramatic. Glad you approve!
Most impressive.
Don't know how many times I've said this in this thread, but thanks again Bjorn.
And now what everyone is here for, more updates.  Been a bit of a while since I've been able to post updates, due to a rather important family crisis, and that combined with the surprise holiday my wife has booked for my 40th birthday in 10 days this may be the only update I manage this month.
So I started work on both 3rd Tactical squad, my apothecary and the Land raider Crusader that will become Captain Uthor's personal ride.
First up we have 3rd tactical.  These guys are armed with a melta gun and a multimelta, both of which are forgeworld resin ones to enable the red LED's to show through.  With the Multimelta I really wanted to use the shoulder mounted version, but it bugged me that there was no fuel cells mounted on it.  With this in mind I combined it with the Backpack and cabling from the Mediant pattern Multimelta.
The apothecary.  Inspired by the new primaris Apothecary I wanted this guy to look like he was a melding of that and the original Apothecary.  To this end, the left hand was replaced with a bolt pistol hand, the right hand was converted from an open left hand and is holding one of the ork skulls from the scout box, and the semsor on the pack was replaced with the loading arm from the missile launcher backpack.
-Yes I am aware of the massive mould line. It has been removed now. Why do these things only show up in photos??
Lastly the Land Raider Crusader "Excalibur"
SO this is a bit more complicated than your average Land Raider. Firstly I wanted to emulate the look of the Spartan with tracks running all the way round. Then Extra armour to house the new headlights and give it that brutal assault tank look.  Lights (obviously) are resin copies of the rhino light housing, though I also added a green LED for the machine spirit and a red LED in the interior.(picture three shows how the battery and the wiring are hidden in the engine compartment which I hinged and magnetised.)
The rear top plate is not attached yet as I'm waiting for some parts to arrive to utilise the second battery hidden in there (in fact the sensor mounted next to the rear hatch is on top of a push switch for this)  What am I waiting for? Miniature 3V motors so I can have a pair of spinning assault cannons in a Spartan style cupola.
Good job binary, keep it up! :smile.: Looking forward to seeing how those assault cannons turn out. :cool.:
Then you're going to love this post then Bob.....
As part of the Tale of Hobbyists 2017 I pledged this month to finish the Apothecary and "try" to get the land raider built.  With a bit of a family crisis and an upcoming surprise holiday (my wife has sprung on me that shes arranged for us to spend my birthday this year in Dubai, as its my 40th) I didn't think I'd manage it, but somehow I have....
I present to you Apothecary Lamoral, Guardian of the legacy.
And The Venerable Land Raider Crusader "Excalibur"
I wanted Excalibur to look more heavily armoured than a normal Land raider, Kind of imitating the look of the Spartan. So Tracks all the way round, Storm raven Hurricane bolters (kindly donated) and a Spartan-esque cupola.
as you can see from the gif the rear sensor is mounted on top of a push switch, so as long as the power switch is on both cannons rotate when the sensor is pushed down.
C&C welcome as usual
