TempestBlade Posted June 9, 2017 Share Posted June 9, 2017 I was looking at all the SW leaks and I saw Logan on sled and thought "Man he is awesome! I should pick him up!". So I am asking for some help. Is he worth the points? He's 230 on the sled. That's a fair amount of points and being 12Ws he can get shot at right away. That being said he's fast (10" move) and has 11 attacks in cc. Im on the fence and I don't want to pick up a model Im not going to use. Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/ Share on other sites More sharing options...
Toasterfree Posted June 9, 2017 Share Posted June 9, 2017 keeps him in range of TWC and allows them to ignore morale. id say its worth it. Hellrender 1 Back to top Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4777951 Share on other sites More sharing options...
TheWolfLord Posted June 10, 2017 Share Posted June 10, 2017 I'm not as convinced. In 7th I loved Stormrider rules but in 8th it takes him above the 10 wound mark for characters meaning he can be targeted as normal. T6 with 12 wounds and a 3+ save doesn't seem very survivable. I need to test him out to see if he's more survivable in practice, as Walter says he brings some great benefits to TWC and fast Wolf Guard units running with him so he could be well worth the disadvantage over the slower version. Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4778666 Share on other sites More sharing options...
postxhumanity Posted June 10, 2017 Share Posted June 10, 2017 I was planning to start a thread similar to this, as I think it's an interesting question whether Logan will be better with Stormrider or on foot. Stormrider has some very obvious benefits, but with all of the changes to 8th edition, it will also come with some drawbacks--the biggest of which is easily the fact that he can be targeted by anyone. It costs an additional 40 points to take Stormrider. Here are the pros and cons as I see them:Pros of Stormrider: -Mobility: Logan's default movement of 5" is doubled to 10" (7" with 4-6 wounds, 4" with 1-3 wounds) -Durability: increased Toughness from 4 to 6; increased Wounds from 7 to 12 -Assault: Ability to reroll charges; 6 additional melee attacks at S 5, AP -1 (5 attacks with 4-6 wounds, 4 with 1-3 wounds) Cons: -Big target: With more than 10 wounds, Logan can be targeted by anyone whose weapon is in range -Armor save: Logan's 2+ armor save on foot is reduced to 3+ on Stormrider -Deployment: Logan loses the ability to deepstrike if he's on Stormrider So, do the pros outweigh the cons? At this point I don't think we can answer definitively. This is an empirical question and most of us just haven't been able to run Logan in the yet-to-be-released 8th edition. I think Stormrider is very likely going to be worth taking against armies that focus on Assault, but suspect that it may prove something a liability against shootier armies if there isn't a lot of LOS blocking cover. Going from 7 to 12 wounds on a model with a 4++ is in some respects a remarkable upgrade, but if it suddenly means you're be targeted by lascannons and meltas, it might not be worth it. This is a longish post for just saying 'I don't know what the answer is.' But I thought it'd be good to lay out the pros and cons of Stormrider. Once we're finally able to use it it 8th edition, I'd love to hear how Logan is working out for people with and without his chariot. Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4778706 Share on other sites More sharing options...
TheDuck Posted June 12, 2017 Share Posted June 12, 2017 I'd say that whether he's worth taking on Stormrider largely depends on what sort of long range firepower your enemy's got. If you're up against Tau, for example, then no, he'll get melted in their shooting phase. But if it's an assault army, like Khorne daemons, then hell yeah, take him on Stormrider, he's absolutely beastly in assault. Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4779995 Share on other sites More sharing options...
Lord Blackwood Posted June 12, 2017 Share Posted June 12, 2017 I feel like id rather him walk around on foot honestly. Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4780028 Share on other sites More sharing options...
Akela Posted June 12, 2017 Share Posted June 12, 2017 Logan on Stormrider is a bit less risky if you have an Iron Priest on Thunderwolf Mount behind him to repair wounds since technically the Stormrider is a Vehicle. postxhumanity 1 Back to top Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4780123 Share on other sites More sharing options...
TempestBlade Posted June 12, 2017 Author Share Posted June 12, 2017 Oooo good call Akela! I forgot about iron priests on Thunderwolves. Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4780408 Share on other sites More sharing options...
Kasper_Hawser Posted June 13, 2017 Share Posted June 13, 2017 Or Iron Priests on bikes. Since TWC no longer increases the strength of thunderhammers, but gives a few extra attacks at S5 AP-1, if one is on budget, may as well use bike Iron Priest which is slightly cheaper I think. Faster than TWC and can choose to jink for 5++ invlun. Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4781164 Share on other sites More sharing options...
Akela Posted June 13, 2017 Share Posted June 13, 2017 True, though I sawed one of the old metal Iron Priest models in half and then pinned it onto a third party Thunderwolf...I am pretty well committed to Iron Priest on TWM ; ) Kasper_Hawser 1 Back to top Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4781185 Share on other sites More sharing options...
Kasper_Hawser Posted June 13, 2017 Share Posted June 13, 2017 True, though I sawed one of the old metal Iron Priest models in half and then pinned it onto a third party Thunderwolf...I am pretty well committed to Iron Priest on TWM ; ) Not too late to take a servo arm from somewhere, attach it to a marine body on a bike and call it an Iron Priest on bike. :) for me, I actually purposely bought the Techmarine with 4 servitors for that purpose, to convert to all kinds of Iron Priest. Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4781207 Share on other sites More sharing options...
TempestBlade Posted June 13, 2017 Author Share Posted June 13, 2017 @Kasper - while the iron priest on a bike is cheaper by 15 points, bike no longer get the jink ability. Only DA ones do unless I am missing something. So on thunderwolf you get another 3 attacks at str 5 ap -1 added to your 3x str 8 ap -3 dmg 3 attacks. Shame too I converted a cool looking iron priest on bike Kasper_Hawser and Valerian 2 Back to top Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4781285 Share on other sites More sharing options...
Gherrick Posted June 13, 2017 Share Posted June 13, 2017 Bike > TWC when that 4" extra movement matters. IP on bike that can make a charge with a tempest hammer means far more than 3 S5/-1 extra attacks. Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4781826 Share on other sites More sharing options...
postxhumanity Posted June 13, 2017 Share Posted June 13, 2017 In the context of repairing Logan's sled, the increased mobility afforded by a bike as opposed to a Thunderwolf doesn't matter. The profiles for the Iron Priest on a bike and on a Thunderwolf both state that a repair can only be performed if the IP hasn't moved more than 6". Valerian 1 Back to top Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4781929 Share on other sites More sharing options...
Kasper_Hawser Posted June 14, 2017 Share Posted June 14, 2017 @Kasper - while the iron priest on a bike is cheaper by 15 points, bike no longer get the jink ability. Only DA ones do unless I am missing something. So on thunderwolf you get another 3 attacks at str 5 ap -1 added to your 3x str 8 ap -3 dmg 3 attacks. Shame too I converted a cool looking iron priest on bike Nuts, so bikes lost the overall jinking ability? So the only benefits is the extra toughness and speed. My mind still stuck in 7th, Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4782394 Share on other sites More sharing options...
TempestBlade Posted June 14, 2017 Author Share Posted June 14, 2017 Yea I'm going to have trouble switching my mind over to 8th for the first few games. Looking at it thunderwolf gives +1 wound, +3 attacks at str 5 ap -1, and a 10" move over the bike for +15 points. I think I will go thunderwolf every time. Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4782444 Share on other sites More sharing options...
Gherrick Posted June 15, 2017 Share Posted June 15, 2017 What you aren't factoring in when comparing WG on bike vs TWC is the shooting difference. WG get access to combis, as well as cheaper SS, plus the bike's twin bolters. IMO, that is worth much more than the extra wound and extra melee attacks. Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4783958 Share on other sites More sharing options...
Wispy Posted June 16, 2017 Share Posted June 16, 2017 (edited) We're talking Iron Priests though. Wolf Guard cant heal Logan in a sled. Edited June 16, 2017 by Wispy Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4784635 Share on other sites More sharing options...
Kasper_Hawser Posted June 16, 2017 Share Posted June 16, 2017 I'm gonna try both anyway. Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4784656 Share on other sites More sharing options...
TempestBlade Posted June 16, 2017 Author Share Posted June 16, 2017 First game I get to play I'm bring Logan on sled with a iron priest on thunderwolf. The extra attacks sounds awesome Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4784941 Share on other sites More sharing options...
Fang_Guard23 Posted June 16, 2017 Share Posted June 16, 2017 Logan on Stormrider is a bit less risky if you have an Iron Priest on Thunderwolf Mount behind him to repair wounds since technically the Stormrider is a Vehicle. not exactly, the iron priest's battlesmith rule says that if he hasn't move more then 6", then he can repair a vehicle. so the iron priest won't exactly be able to fully keep up with grimnar if he's too far away. Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4784966 Share on other sites More sharing options...
NightHowler Posted June 16, 2017 Share Posted June 16, 2017 Just take several Iron Priests in drop pods and drop them wherever Logan will move to next. Like a kind of "Iron Priest Pit Stop" Logan pulls up, gets some quick repairs and an oil change, and zips off to the next battle. Since we now decide exactly when and where deep strike reserves arrive, you're guaranteed to have an "Iron Priest Pit Stop" when and where you need it most. Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4784981 Share on other sites More sharing options...
Gherrick Posted June 16, 2017 Share Posted June 16, 2017 If only we could get IPs in TDA like techmarines, as that would work better for pit stop repairs. Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4784990 Share on other sites More sharing options...
Nrthstar Posted June 24, 2017 Share Posted June 24, 2017 Anyone done it yet? The sled that is? Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4795097 Share on other sites More sharing options...
CJAMOMAN Posted July 31, 2017 Share Posted July 31, 2017 (edited) I have played the sled once. It sucked. With being able to be targeted, and not really having the resilience that other high wound models have, he dies in 1 round of shooting. I think he needs more wounds or more T to make it worth it. Edited July 31, 2017 by CJAMOMAN Link to comment https://bolterandchainsword.com/topic/334508-is-logan-grimnar-on-sled-worth-it-in-8th/#findComment-4839271 Share on other sites More sharing options...
