Bloody Legionnaire Posted June 9, 2017 Share Posted June 9, 2017 So I just attempted airbrushing GWs HH Space Wolves scheme (hoping it was similar to FWs) and the end product came out much a much lighter shade of grey than what I was going for. Anyone have any tips for filtering or darkening down a light shade of grey? I thought about airbrushing nuln oil over top but I didn't know if that would wind up being to harsh of a dark tint. Link to comment https://bolterandchainsword.com/topic/334514-darkening-grey/ Share on other sites More sharing options...
Bryan Blaire Posted June 9, 2017 Share Posted June 9, 2017 You could try thining a grey down to a wash and using that. Depending on how dark you want to get it, Nuln Oil could make the model darker than you wanted it to get. Edit: Sorry, realized you said GW HH Space Wolves, not the normal GW Space Wolves. Link to comment https://bolterandchainsword.com/topic/334514-darkening-grey/#findComment-4778099 Share on other sites More sharing options...
Kinstryfe Posted June 10, 2017 Share Posted June 10, 2017 Unless you're going for a full repaint, you'll need to look at some sort of wash. The quick options would be either black or a darker grey applied where wanted. If you have something you can paint up quickly to experiment on, you may want to try adding other tones. I've had pretty results adding a touch of sepia with dark washes to not go fully black, and I know a lot of people may use blue as an off-black offset to tinge the grey slightly. I'd start by testing mostly black or grey depending on how dark you want, and mix it up a little depending on how you like those results. Edit: forgot to add, I've good results thinning out black washes and spot applying them instead of doing an all over wash. Link to comment https://bolterandchainsword.com/topic/334514-darkening-grey/#findComment-4778229 Share on other sites More sharing options...
Bloody Legionnaire Posted June 10, 2017 Author Share Posted June 10, 2017 Yeah I basically ended up doing a 50:50 of glaze medium to nuln oil and it worked out pretty well. Thanks for the help fellas! Link to comment https://bolterandchainsword.com/topic/334514-darkening-grey/#findComment-4778264 Share on other sites More sharing options...
