Corbulo Posted June 12, 2017 Share Posted June 12, 2017 Hey guys, Some units have the keywords, Monster or Building and I can't find what these mean in game play. Can anyone help a brother out? Thanks! Link to comment https://bolterandchainsword.com/topic/334629-8th-edition-keywords/ Share on other sites More sharing options...
Kristoff Posted June 13, 2017 Share Posted June 13, 2017 Some rules affect Monsters and Buildings more or less than others. The Emperor's Champion's Black Sword gains a bonus against Monsters and Characters, for example. Link to comment https://bolterandchainsword.com/topic/334629-8th-edition-keywords/#findComment-4781144 Share on other sites More sharing options...
Eddie Orlock Posted June 18, 2017 Share Posted June 18, 2017 Indeed, many keywords are likely going to be pure hooks for interaction with other effects without specific impact of their own. Unchained as promised. Link to comment https://bolterandchainsword.com/topic/334629-8th-edition-keywords/#findComment-4788002 Share on other sites More sharing options...
Theis Posted June 23, 2017 Share Posted June 23, 2017 So there's no list of keywords and their definitions anywhere? It's just, in the data sheet there are the keywords for that unit, and somewhere in the rest of the rules, or on some other datasheet, somewhere, that keyword is defined or used as a hook of some sort? Sorry if that's a newb sort of question, but I'm just now getting into 8th, and haven't had time to do an exhaustive read of the rules and indices yet. Link to comment https://bolterandchainsword.com/topic/334629-8th-edition-keywords/#findComment-4794407 Share on other sites More sharing options...
Acebaur Posted June 23, 2017 Share Posted June 23, 2017 Basically if you have a keyword on that datasheet then it doesn't really do anything other than assign it to that group of keywords. Other units may have an ability that specifically affects that keyword. Using the example the Emperor's Champion's Black sword has an ability that only affects monsters and characters. Another one is that Helbrecht gives re-rolls to all nearby Black Templars. It's just a way to define what a unit is but doesn't actually grant rules in and of itself. does that make more sense? Link to comment https://bolterandchainsword.com/topic/334629-8th-edition-keywords/#findComment-4794440 Share on other sites More sharing options...
Theis Posted June 23, 2017 Share Posted June 23, 2017 Yep, sure does, thank you. The, "Fly" keyword for example, though, I've seen references like this on a Spikeybits article; If the datasheet for a model contains the Fly keyword, it can move across terrain and units as if they were not there. Models with the Fly keyword have a Move characteristic of consisting of two values: minimum and max speed: It must move its minimum and cannot go beyond its maximum. If it is unable to move its minimum or is forced off the battlefield because of its minimum speed, it is destroyed and removed from the battlefield – the model has either stalled and crashed or forced to abandon the field I take it that's just defined somewhere in the movement rules? Obviously, I need to spend sometime reading this weekend, just looking to clear up some confusion before I have the opportunity to. Thanks again. Link to comment https://bolterandchainsword.com/topic/334629-8th-edition-keywords/#findComment-4794463 Share on other sites More sharing options...
Kristoff Posted June 23, 2017 Share Posted June 23, 2017 Yep, sure does, thank you. The, "Fly" keyword for example, though, I've seen references like this on a Spikeybits article; If the datasheet for a model contains the Fly keyword, it can move across terrain and units as if they were not there. Models with the Fly keyword have a Move characteristic of consisting of two values: minimum and max speed: It must move its minimum and cannot go beyond its maximum. If it is unable to move its minimum or is forced off the battlefield because of its minimum speed, it is destroyed and removed from the battlefield – the model has either stalled and crashed or forced to abandon the field I take it that's just defined somewhere in the movement rules? Yeup. Page 3 of the Primer. Link to comment https://bolterandchainsword.com/topic/334629-8th-edition-keywords/#findComment-4794532 Share on other sites More sharing options...
Theis Posted June 23, 2017 Share Posted June 23, 2017 (edited) Cool, thanks again. A thorough reading of the rules was on the weekend's agenda anyhow. So, doubly so now. Much appreciated. Edited June 23, 2017 by Theis Link to comment https://bolterandchainsword.com/topic/334629-8th-edition-keywords/#findComment-4794566 Share on other sites More sharing options...
