DreamIsCollapsing Posted June 18, 2017 Share Posted June 18, 2017 Hi, After failing my research of a great Blastmaster count as/proxy, i was asking if someone ever tried to convert a forgeworld sonic blaster into blastmaster by cutting the end and greenstuffing a longer barrel ? Still on Noise marines, any idea of wich paint (GW or Vallejo reference) to get this OSL effect on sonic weapon : And last question, anyone get an idea to represent Eternal Hunger on Chaos Tank for the poor souls without a green(stuff) fingers ? Some bits idea ? The Nephilim 1 Back to top Link to comment https://bolterandchainsword.com/topic/334933-blastmaster/ Share on other sites More sharing options...
hushrong Posted June 18, 2017 Share Posted June 18, 2017 I have seen a few conversions while randomly browsing google. One I remember was taking the long barrel of the GW blastmaster and fitting it onto a FW cacophony. I myself use the FW weapons for sonic blaster while I made my own blastmaster to set them apart. Basically I cut up a gravcannon and added bits to it. One idea I would like to throw out there for a blastmaster. Major_Gilbear, The Nephilim and DreamIsCollapsing 3 Back to top Link to comment https://bolterandchainsword.com/topic/334933-blastmaster/#findComment-4787443 Share on other sites More sharing options...
DreamIsCollapsing Posted June 20, 2017 Author Share Posted June 20, 2017 Yep, that was what i had i mind. I see you got a forgeword sonic blaster too, did you try to turn one of those into blastmaster with the same method ? Link to comment https://bolterandchainsword.com/topic/334933-blastmaster/#findComment-4790533 Share on other sites More sharing options...
hushrong Posted June 20, 2017 Share Posted June 20, 2017 I have not. I preordered the Kakophoni the moment they went up. When I finally got them I used them as my blastmasters for a long while. Then I found a treasure trove of the guns on eBay and decided since I started making my own blastmasters I will use the FW goodies as sonic blasters. I had been thinking of extentinding the barrel and adding tubing that would end in openings similar to trumpets and other horn instruments. Just to make it look like it pushed out more noise as a blastmasters does. I feared it would look like something from Dr. Seuss however. Link to comment https://bolterandchainsword.com/topic/334933-blastmaster/#findComment-4791079 Share on other sites More sharing options...
