Brother Ambroz Posted June 21, 2017 Share Posted June 21, 2017 (edited) What legs scale well with a regular plastic dreadnought? Apart from sentinel legs that is. Has anyone ever tried carnifex and/or hive tyrant legs? Want to do either a daemon engine or dreadnought conversion for context. Edited June 21, 2017 by Tanith Ghost Link to comment https://bolterandchainsword.com/topic/335383-alternative-dreadnought-sized-legs/ Share on other sites More sharing options...
Aeternus Posted June 21, 2017 Share Posted June 21, 2017 I know somewhere someone sells legs designed for use as Contemptor-Cortus legs (slightly more mechanical/rough), so they might work alright if you were staying away from the biological side. Example http://i.imgur.com/dLh4kFB.jpg Link to comment https://bolterandchainsword.com/topic/335383-alternative-dreadnought-sized-legs/#findComment-4792268 Share on other sites More sharing options...
Brother Ambroz Posted June 21, 2017 Author Share Posted June 21, 2017 Oh wow that is pretty nice! Might use those too but this particular instance I'm referring to a castaferrum pattern (think that's what the regular ones are called). Link to comment https://bolterandchainsword.com/topic/335383-alternative-dreadnought-sized-legs/#findComment-4792281 Share on other sites More sharing options...
Jolemai Posted June 21, 2017 Share Posted June 21, 2017 I know somewhere someone sells legs designed for use as Contemptor-Cortus legs (slightly more mechanical/rough), so they might work alright if you were staying away from the biological side. Example http://i.imgur.com/dLh4kFB.jpg Do you have a board-friendly link for those legs? They look rather interesting. Link to comment https://bolterandchainsword.com/topic/335383-alternative-dreadnought-sized-legs/#findComment-4792298 Share on other sites More sharing options...
Aeternus Posted June 21, 2017 Share Posted June 21, 2017 (edited) I know somewhere someone sells legs designed for use as Contemptor-Cortus legs (slightly more mechanical/rough), so they might work alright if you were staying away from the biological side. Do you have a board-friendly link for those legs? They look rather interesting. I presume an ebay link is board friendly? Here, from Blood and Skull. Shapeways also have a version, but thats £40 instead... Shipping is a bit of a pain, but they've got a bunch of other cool vehicle stuff if you want to combine postage. Oh wow that is pretty nice! Might use those too but this particular instance I'm referring to a castaferrum pattern (think that's what the regular ones are called). Ah, my bad, didn't realise you were sticking particularly with castaferrum. Just thought the box might actually look almost ambulatory on Contemptor style. Can't say whether tyranid legs would properly give off the demon vibe, and DP legs might be a bit too thin unless you GS'd them out like Augustus is doing to a Bloodthirster's. Aside from those, only other model I can think of is the helbrute itself, or perhaps a penitent engine. Oh wow that is pretty nice! Might use those too but this particular instance I'm referring to a castaferrum pattern (think that's what the regular ones are called). Edited June 21, 2017 by Aeternas Link to comment https://bolterandchainsword.com/topic/335383-alternative-dreadnought-sized-legs/#findComment-4792311 Share on other sites More sharing options...
Jolemai Posted June 21, 2017 Share Posted June 21, 2017 Huh, had no idea Blood and Skull Industries had started to make them. Cheers. Aeternus 1 Back to top Link to comment https://bolterandchainsword.com/topic/335383-alternative-dreadnought-sized-legs/#findComment-4792316 Share on other sites More sharing options...
Tyberos the Red Wake Posted June 22, 2017 Share Posted June 22, 2017 That inbuilt fist weapon with the coils protruding from the casing is so awesome. Link to comment https://bolterandchainsword.com/topic/335383-alternative-dreadnought-sized-legs/#findComment-4792422 Share on other sites More sharing options...
Carlson793 Posted June 22, 2017 Share Posted June 22, 2017 That inbuilt fist weapon with the coils protruding from the casing is so awesome. Comes standard on certain FW Contemptor arms (click pic for link): Link to comment https://bolterandchainsword.com/topic/335383-alternative-dreadnought-sized-legs/#findComment-4793753 Share on other sites More sharing options...
Honda Posted June 25, 2017 Share Posted June 25, 2017 Hah! I just got a pair of those legs. Brilliant! Thank you for the tip. Link to comment https://bolterandchainsword.com/topic/335383-alternative-dreadnought-sized-legs/#findComment-4796792 Share on other sites More sharing options...
