Mightykin Posted June 22, 2017 Share Posted June 22, 2017 This thread is created to present questions about 8th edition rules and point costs for blood angels (only). My example: Under the furioso dreadnought entry it says smoke launchers can be taken. The smoke launchers are not in the war gear of the furioso and they do not have point costs in the reference tables in the back. Anyone else found this issue or knows the solution? M Link to comment https://bolterandchainsword.com/topic/335440-8th-edition-rulepoint-clarification/ Share on other sites More sharing options...
Jolemai Posted June 22, 2017 Share Posted June 22, 2017 Smoke launchers are only listed as an ability in the entirety of Imperium 1 and abilities do not cost any points. As for the Furioso (and DCD), it only talks about replacing it with a magna grapple (costs listed at the back) - whereby you're basically swapping the ability for a new one. Morticon 1 Back to top Link to comment https://bolterandchainsword.com/topic/335440-8th-edition-rulepoint-clarification/#findComment-4793620 Share on other sites More sharing options...
Kamahl129 Posted June 25, 2017 Share Posted June 25, 2017 (edited) Hello, I am actually confused about the cost per model for Sanguinary Guard. The Codex states that a single model costs 22 points without war-gear, does that actually mean that a single SG model actually costs a minimum of 44 points? If so does that mean the SG Ancient Costs 106 points? **Minimum points would include Angelus Boltgun and Encarmine sword** Edited June 25, 2017 by Kamahl129 Link to comment https://bolterandchainsword.com/topic/335440-8th-edition-rulepoint-clarification/#findComment-4796274 Share on other sites More sharing options...
NTaW Posted June 25, 2017 Share Posted June 25, 2017 (edited) On 6/25/2017 at 2:47 PM, Kamahl129 said: Hello, I am actually confused about the cost per model for Sanguinary Guard. The Codex states that a single model costs 22 points without war-gear, does that actually mean that a single SG model actually costs a minimum of 44 points? If so does that mean the SG Ancient Costs 106 points? **Minimum points would include Angelus Boltgun and Encarmine sword** Seems like you've got it right. Unless it's specifically stated that equipment is included (like with Mephiston or Dante) wargear is extra. EDIT: I will add that the plasma pistol is less than the angelus boltgun for Sanguinary Guard and the minimum cost is 42 points. Edited June 25, 2017 by NTaW Link to comment https://bolterandchainsword.com/topic/335440-8th-edition-rulepoint-clarification/#findComment-4796278 Share on other sites More sharing options...
Jolemai Posted June 25, 2017 Share Posted June 25, 2017 That's how it's worked out, yes. Link to comment https://bolterandchainsword.com/topic/335440-8th-edition-rulepoint-clarification/#findComment-4796280 Share on other sites More sharing options...
