Daimhin Posted June 23, 2017 Share Posted June 23, 2017 I've decided that I want to run a Canoness with a Jump Pack. I know that I can't run one under the current rules in a pick-up/ tournament game, however, I am fortunate enough that I can certainly run one when I play my friends. Obviously, I want to do this in a fair manner, so I have looked at various Space Marine characters and seen what they get when upgraded to have a Jump Pack and how their points increases. So I thought I'd share it with you. What you get when you upgrade to have a Jump Pack Move characteristic goes from 6" to 12" Gain keywords: "JUMP PACK" and "FLY" Sky Strike (as per Seraphim) Points cost I looked at the following: Captain 74 Captain with Jump Pack 93 Chaplain 72 Chaplain with Jump Pack 90 Librarian 93 Librarian with Jump Pack 116 What I noticed is that in all these cases the Jump Pack character is 125% of the cost of the same, non-Jump Pack, character. ( 74 x 1.25 = 92.5 ) ( 72 x 1.25 = 90 ) ( 93 x 1.25 = 116.25 ) Therefore, a Canoness with Jump Pack should cost 56 points. ( 45 x 1.25 = 56.25 ) Atrus, GodwynDi and Warsmith Aznable 3 Back to top Link to comment https://bolterandchainsword.com/topic/335478-canoness-with-jump-pack/ Share on other sites More sharing options...
Gen.Steiner Posted June 23, 2017 Share Posted June 23, 2017 Thank you. That's actually a pretty decent little fix; I don't know why GW didn't supply this. Maybe in the (dreamed for, wished for, hoped for, prayed for) upcoming Codex: Adeptus Ministorum... Link to comment https://bolterandchainsword.com/topic/335478-canoness-with-jump-pack/#findComment-4794142 Share on other sites More sharing options...
Atrus Posted June 23, 2017 Share Posted June 23, 2017 Very cool. I wouldve guessed just add 20 pts as i think the jump pack upgrade in the witch hunter dex was that much or there abouts. Good to have a solid number to work with for cool opponents in friendly games. I presume such a Canoness' PL listing would jump up to a 5 easy. Link to comment https://bolterandchainsword.com/topic/335478-canoness-with-jump-pack/#findComment-4794162 Share on other sites More sharing options...
Daimhin Posted June 23, 2017 Author Share Posted June 23, 2017 (edited) Yes, I forgot to put that. PL goes up by 1 for each Space Marine character, so yes, Canoness becomes PL5. I have a dataslate as a pdf if anyone wants it Edited June 23, 2017 by Daimhin Link to comment https://bolterandchainsword.com/topic/335478-canoness-with-jump-pack/#findComment-4794170 Share on other sites More sharing options...
radionausea Posted June 23, 2017 Share Posted June 23, 2017 I'd love a copy of that dataslate Link to comment https://bolterandchainsword.com/topic/335478-canoness-with-jump-pack/#findComment-4794232 Share on other sites More sharing options...
Daimhin Posted June 23, 2017 Author Share Posted June 23, 2017 https://www.dropbox.com/s/ui6zaaf35icr6t6/Canoness%20with%20Jump%20Pack.pdf?dl=0 Link to comment https://bolterandchainsword.com/topic/335478-canoness-with-jump-pack/#findComment-4794241 Share on other sites More sharing options...
Drider Posted June 23, 2017 Share Posted June 23, 2017 i'd be interested to see if this breakdown would work for bikes as well. Link to comment https://bolterandchainsword.com/topic/335478-canoness-with-jump-pack/#findComment-4794583 Share on other sites More sharing options...
Gen.Steiner Posted June 24, 2017 Share Posted June 24, 2017 Shouldn't it read:"This model may replace its bolt pistol and/or chainsword with an inferno or plasma pistol"?As it stands you can only have one pistol, not two, or have I missed identical wording on the offical datasheet... Link to comment https://bolterandchainsword.com/topic/335478-canoness-with-jump-pack/#findComment-4795232 Share on other sites More sharing options...
Daimhin Posted June 24, 2017 Author Share Posted June 24, 2017 I believe my wording is correct. If you swap the chainsword for a pistol then you can have two pistols. I should amend it to state she can swap the chainsword for a bolt pistol actually Gen.Steiner 1 Back to top Link to comment https://bolterandchainsword.com/topic/335478-canoness-with-jump-pack/#findComment-4795252 Share on other sites More sharing options...
Atrus Posted June 24, 2017 Share Posted June 24, 2017 Just use the same wording as in the book ie may swap chainsword for either a weapon from the ranged wep list or pistols list. Link to comment https://bolterandchainsword.com/topic/335478-canoness-with-jump-pack/#findComment-4795278 Share on other sites More sharing options...
Daimhin Posted June 24, 2017 Author Share Posted June 24, 2017 That's not actually what it says in the book. Link to comment https://bolterandchainsword.com/topic/335478-canoness-with-jump-pack/#findComment-4795365 Share on other sites More sharing options...
Gen.Steiner Posted June 24, 2017 Share Posted June 24, 2017 I see her as a Seraphim veteran really. Pistols and melee weapons only. Perhaps:This model may exchange her bolt pistol and/or chainsword for any weapon from the Adepta Sororitas Melee Weapons or Pistol Weapons lists. Not 100% on the wording but that way you can have two pistols or two melee weapons or one of each. Link to comment https://bolterandchainsword.com/topic/335478-canoness-with-jump-pack/#findComment-4795372 Share on other sites More sharing options...
Servant of Dante Posted June 24, 2017 Share Posted June 24, 2017 In my homebrew codex, I gave the Canoness a jump pack option, but I also made the Seraphim Superior a HQ choice (though Seraphim and Seraphim Superiors are a bit more beefy when I'm writing the rules; they're supposed to be the most Veteran Sisters, and their stat line does not reflect that). Link to comment https://bolterandchainsword.com/topic/335478-canoness-with-jump-pack/#findComment-4795390 Share on other sites More sharing options...
radionausea Posted June 26, 2017 Share Posted June 26, 2017 Thank you for the pdf Link to comment https://bolterandchainsword.com/topic/335478-canoness-with-jump-pack/#findComment-4798213 Share on other sites More sharing options...
