feuer_faust Posted June 24, 2017 Share Posted June 24, 2017 (edited) I don't have the new rule book yet, just the Primer, but it seems like weapon arcs are gone this edition? The primer says you measure from base to base or use the hull if no base exists... do the "advanced" rules go into arcs and whatnot, or is it as loosey-goosey as it seems? In a related note, LOS is required to shoot something, but a model only ignores models in its own unit for shooting. That implies to me that you can effectively preveny your own units from shooting of you're not leaving gaps for therm to fire through, correct? Edited June 24, 2017 by feuer_faust Link to comment Share on other sites More sharing options...
Captain_Krash Posted June 24, 2017 Share Posted June 24, 2017 (edited) No arcs what so ever just need to be able to draw a line to the model shooting to the model being shot at. And you are correct a unit ignores others within there unit for shooting/line of sight. But if you have another unit in front of that unit unless you spaced it properly then the unit behind cannot shoot past the unit which is blocking it's line of sight. Krash Edited June 24, 2017 by Captain_Krash feuer_faust 1 Back to top Link to comment Share on other sites More sharing options...
feuer_faust Posted June 25, 2017 Author Share Posted June 25, 2017 Thanks for the clarification, it does open up some possibilities. Link to comment Share on other sites More sharing options...
