GriffonI92 Posted June 27, 2017 Share Posted June 27, 2017 I have been using Tamiya Color X-20A Thinner to clean my airbrush but sadly I just ran out of my big bottle that I thought would last forever. Just curious is their a sort of home remedy solution I can use or just best bet to buy more? Link to comment https://bolterandchainsword.com/topic/335690-airbrush-cleaning-solution/ Share on other sites More sharing options...
MikhalLeNoir Posted June 27, 2017 Share Posted June 27, 2017 Airbrush cleaner from valejo. Or you could use thinned melerud, or americans have this green blablub. Just check if it attacks the rubber used in the airbrush to isolate things. Link to comment https://bolterandchainsword.com/topic/335690-airbrush-cleaning-solution/#findComment-4798809 Share on other sites More sharing options...
Imren Posted June 27, 2017 Share Posted June 27, 2017 If your airbrush have PTFA/teflon seals then regular acetone works fine (If your seals are not PTFA/teflon, acetone may dissolve them). some seals might swell after immersion for too long, but they come down to regular shape after a few hours of drying after your cleaning. so don't insert your needle for 5-6 hours after cleaning in acetone. Link to comment https://bolterandchainsword.com/topic/335690-airbrush-cleaning-solution/#findComment-4799507 Share on other sites More sharing options...
micahwc Posted June 27, 2017 Share Posted June 27, 2017 Windex seems to work. I've been using it for about two years without any problems. Some say the ammonia is bad for the seals, but I haven't had any problems so far. Link to comment https://bolterandchainsword.com/topic/335690-airbrush-cleaning-solution/#findComment-4799569 Share on other sites More sharing options...
Bloody Legionnaire Posted June 28, 2017 Share Posted June 28, 2017 Honestly I use water for the majority of my cleaning for my acrylics paints and if I end up with some really dried up crud in my paint cup I'll use Simple Green a cotton swab and a toothpick. For enamel and lacquer paints I use Lacquer thinner. Link to comment https://bolterandchainsword.com/topic/335690-airbrush-cleaning-solution/#findComment-4800236 Share on other sites More sharing options...
jbaeza94 Posted June 29, 2017 Share Posted June 29, 2017 I have just purchased a sonic cleaner for 25 usd. i hear they do wonders for airbrushes with just just water and windex. i have a large one for my firearms, and its amazing how well they clean. if you want to try the tech route, give these a look on youtube. They also work for stripping models with purple power. Link to comment https://bolterandchainsword.com/topic/335690-airbrush-cleaning-solution/#findComment-4801871 Share on other sites More sharing options...
TheHarrower Posted June 29, 2017 Share Posted June 29, 2017 I have just purchased a sonic cleaner for 25 usd. i hear they do wonders for airbrushes with just just water and windex. i have a large one for my firearms, and its amazing how well they clean. if you want to try the tech route, give these a look on youtube. They also work for stripping models with purple power. Where did you score that so cheap? Link to comment https://bolterandchainsword.com/topic/335690-airbrush-cleaning-solution/#findComment-4802260 Share on other sites More sharing options...
jbaeza94 Posted June 29, 2017 Share Posted June 29, 2017 https://www.amazon.com/gp/aw/d/B001DKDAVW/ref=mp_s_a_1_4?ie=UTF8&qid=1498760396&sr=8-4&pi=AC_SX236_SY340_FMwebp_QL65&keywords=ultrasonic+cleaner&dpPl=1&dpID=31JlJNfXW7L&ref=plSrch Link to comment https://bolterandchainsword.com/topic/335690-airbrush-cleaning-solution/#findComment-4802371 Share on other sites More sharing options...
